I put together a 402BBC w/spare parts closed chamber ret ports about 12.5-1 cr for my twice a month bracket car.
The question is how much spring pressure to run as it is a cast core street type roller cam.
Specs are Int .656 244°@.05 & Ex .676@256° ona 110°LS
This was a stick I had taken out of a job and is in fine shape hopin to run high 10's @3200lbs on alky .
BBC cam & Valve spring questions??
- Show Guest
valve springs
I have run 185-190 on the seat, and 500 open and never heard baack from the customer on the cast steel roller cores.
JOE SHERMAN RACING ENGINES
Normally I might run a comp 944-16 on that, but it's a Predator cast cam core. I'm not sure how much it can take.ClassicComp wrote:69 views and not 1 comment??
whats the site commin to......
A lighter spring like a comp 953-16 might work.
10's with a 402
Back in the 1980s I had a customer running 10.68 with a 3200 lb Camaro with a 402 in it. His cam was an UltraDyne FLAT TAPPET BB296/304F8.
I recommended 135lbs on the seat, 335lbs open, give-or-take 5lbs either way.
The cam was 263/271 at .050", and .630"/.630" gross valve lift, 108 LSA, in the engine on 102 ICL.
It ran only 10.96s with a Holley 110 and 1 regulator. Changing jets would not help.
I had him change to 2 regulators and a Y-Block, and a Moroso helper spring in the Pump. It ran the 10.68s the day he changed.
The 296 has gone 100,000 miles on the street as a 288/296F7 or F10.
The 304 is a little milder.......
UDHarold
UDHarold
662-562-4933
brookshire@panola.com
