Greg D wrote:Would it help to crutch an insufficient flowing head with a cam that has tighter LCA's?
CamKing wrote:Greg D wrote:Would it help to crutch an insufficient flowing head with a cam that has tighter LCA's?
No.
You tighten up the lobe centers when you have too big of a port, and widen them when the port is too small.
Greg D wrote:CamKing wrote:Greg D wrote:Would it help to crutch an insufficient flowing head with a cam that has tighter LCA's?
No.
I guess I am a bit confused, In a David Vizard article, he states The bottom line is that LCA's are related to how big a cylinder the intake valve has to feed. The bigger the cylinder in relation to the valve, the tighter the LCA needs to be.
Can you expand?
CamKing wrote:Greg D wrote:CamKing wrote:Greg D wrote:Would it help to crutch an insufficient flowing head with a cam that has tighter LCA's?
No.
Can you expand?
Two things to remember about David, He get's paid by the word, and he doesn't build real race engines.![]()
When your port doesn't flow enough air, where do you see the biggest loss in power?
What normally happens to the power curve when you spread out the Lobe centers?
When your port is too big, where do you see it hurt the power?
What normally happens to the power curve when you tighten the Lobe centers?
We change the lobe centers to band-aid the port's problem.
Users browsing this forum: Sprinter99 and 11 guests
