REAR SHOCK ANGLES
REAR SHOCK ANGLES
What is the preferred shock mounting angle for a 4 link car? Straight up or is it ok to lean them in at the top mount? If so, what is the maximun angle to lean them in? thanks......Rick
- New Member
Most drag cars have the shocks verticle but this is not a necessity. When you mount the shocks at an angle the spring rate needed is different and the response to shock valving changes is not as direct. I have seen shocks in drag cars mounted at many different angles including horizontal using a rocker cantelever system. It is not all that important in my opinion.
Ed
Ed
- jmarkaudio
Shock angle
Also something to consider, by setting the shocks at an angle you lose a small amount of travel.
Mark Whitener
Mark Whitener
- BillyShope
Re: Shock angle
Mark has hit upon what is usually the deciding factor. The less shock travel available, the more vertical the mounting. The greater the departure from vertical, the more shock coefficient (stiffer) you need. (Unless...as Ed described...you have some sort of linkage actuating the shock.)
http://home.earthlink.net/~whshope
