My question, though, is there a formula to prescribe ideal or suggested CA if only RPM, CID and number of cylinders is known?
I have also used Jim McFarland's formula for calculating the torque peak in and engine. The formula is: the smallest CSA of the intake track x 88200 divided by the cubic inches of one cylinder. Example 557 big block chevy.
3.9 x88200=343980. Divide that by 69.625 =4940. This seems a little low and there is a considerable spread in rpm difference in the two different calulations somewhere in the range of 2500 rpm, maybe more. Peak horsepower should occur with 1300-1600 rpm of peak torque in most applications
maxracesoftware wrote:
a pretty good Formula to use is :
CA = ( Bore * Bore * Stroke * RPM * .00353 ) / 614 FPS
where RPM equals Point of Peak HP
and CA is the smallest or minimum cross-sectional area in the Int System
but be careful, that is only the theoretical minimum area
Thanks. Is not that also based upon a Mach .55 derivation where 614 fps=.55*1116fps?
Users browsing this forum: 540 Vette, gmc406, Google [Bot], mustangmike68, racerx1622, Sprinter99 and 7 guests
