by ralph85 » Wed Sep 26, 2007 6:25 pm
My nephew has gotten into running a 10.0 index class. The problem is in the summer heat, he can't run the number. It's due for a freshen up this winter and I'd like some ideas on where to find the additional HP. Car has run a best of 9.90 @ 136, but in mid-summer it's usually in the 10.20s. short times range from low 1.3s to low 1.4s depending on weather and track conditions.
The car is 3300# w/driver, TH 350 w/brake, ATI 8" converter (flashing to 5-5.5K), 4.11 gears and 28" tires. The engine combo is a Dart block 434 with a fairly heavy rotating assembly. Heads are Brodix M2 Track 1s with some minor cleanup (230cc intake), 59 cc chambers for 12.5:1 CR. Intake is a port matched super victor with a 4500 flange, converted to EFI with a 2000 cfm TB on top. Cam is a crower 260/272 @ 50 on a 106 LSA installed straight up with about .710 net lift at the valve. Headers are 1 3/4 to 3" pipes and mufflers (required).
Would like to hear some ideas to knock off 2-3 tenths. We're NOT looking to go 18 deg, shaft mouted rockers or power adders. We're already tight on PV clearance so moving the cam or increasing valve lift would probably require cutting the pistons (not out of the question). I've got some ideas, but would like to hear from the experts. Thanks!
BTW, i read the 12 page thread on the "disappointing power from 434" and many of you feel it's easy to get over 700hp out one of these and i don't think we're there yet.
Ralph
