Its a sb 406 thats giving me a real headache.The main bearings keep failing.It had a stock crank in it and never gave me any trouble until i took it apart last winter to freshen it up.I put new rings, bearings valve springs and anything else that it needed.It started knocking the first weekend at the track.So i took it out and got the crank cut and new bearings and still had trouble.Then i got another block ( had it line honed) and the crank cut again and this time i did'nt stop until a spun a main bearing in the block.Then i said that the crank must be bent and the machine shop is not seeing it in their machine.Now i got a new scat crank and a new dart little m block.Had it running for about 10 minites and the oil is like gold metellic paint just like every other time i had trouble.Both cranks were balanced and everything else looks good when i take it apart.I don't know what to do with this thing,i got a few bucks spent now and can't get no where.Anybody got any ideas about what could be causing this?
P.S JUst found this site about a week ago and i think its great.Lots of good info on here.
