-Here's that same info incase you want to reread thru it.
http://www.stockcarracing.com/techarticles/scrp_0508_carburetor_cures/ -fix for nozzle pullover for Holley 4412's
-another discussion of nozzle pullover on dominator carburetors and some discussion on fixing it.
http://speedtalk.com/forum/viewtopic.php?t=5583&start=15
-Ok fixed the problem,,first it was a vibration induced agitation of the squirter circuit in this case.
-After trying several other fixes including, flush grinding the nozzels, springs on top of lead balls under the squirter, drilling a .028 hole in the channel to help vent off any signal, (didn't work here), two things in combination fixed it.
-Changing the bowls over to the older style with the ball valve in the pump cavity, and machining up new squirter needles from brass needles with a viton tip on the bottom.
-These were made both longer and larger in diameter to try and increase the weight.
-These two have all but cured the problem, a vibration present in some engine combinations.
-here's a link to Ryan Browns dyno videos of the problem.
http://ryanbrownracing.com/Video.html
-I first read about a guy in NY--Richie Zuhl I think--who was dynoing a tunnel ram with 660's (if I remember the story right)---was going rich on top end----so he got up on top of the engine and watched what was happening--found it to be nozzle pullover.
-Then dealing with 350 & 500 Holley two barrel carburetors on oval track cars----and dealing with the Pinto 4 cylinder at Bonneville begets you experience with this problem.
