I have two, they were assembled one each way.
I have two pics off the net, same thing.
It does matter, there's a piston in the piston.
I'm too lazy to work out how it works to then decide.
GM Brake prop valve piston which way ?
Re: GM Brake prop valve piston which way ?
The bottom pic in your post shows the valve/shuttle pointing backwards as the pintle sticks out the end of the valve body.
One cutaway
cutaway diagram
two more cutaway versions
62-67 Nova cutaway
If you use google, insert "before:2023" and then type in your search, you can get a lot of images of proportioning valves. I used "before:2023 GM brake proportioning valve cutaway" and came up with the cutaways and diagrams.
In the big picture, if the barrel with the o-ring is backwards, you'll either get premature rear brake lockup or the brake light will come on during bleeding and never go off (if the ignition is on), requiring a reset and reassembly with the o-ring barrel position reversed.
One cutaway
cutaway diagram
62-67 Nova cutaway
Cheers, looks like this is an Aussie only version, quite a bit different to the US one.
