Head gasket failure - Fire rings crushed?
Nut124
Post by Nut124 »
Asking for a fella on another forum. His Fiat twin cam head gasket blew under load in an uphill.
The fire rings of the gasket in all 4 cylinders are crushed flat as if hit by the pistons, all the way around. Piston contact was ruled out though due to the size of the bores in the gasket.
Detonation? Pre-ignition?
The engine had cranked 150psig. Plugs came out clean w white insulation. One plug had what looked like molten aluminum specs.
rp930
Re: Head gasket failure - Fire rings crushed?
Post by rp930 »
Looks like detonation to me.
mag2555
Post by mag2555 »
White plugs and clear signs of detonation will do that.
I would check the rod bearings now.
biskma
Post by biskma »
Just like to realize if four.10 whats advertised is after overwhelmed like compression thickness is. If it is I will miss a nick from the die grinder lol. Using it on a four.030 bore, do not need all of the compression either.
BOOT
Post by BOOT »
Do you have a new unused gasket to directly compare/measure to the blown gasket fire rings? I am no headgasket expert and there are obvious other problems but that is not what you asked about. Again not a gasket expert, don't know what material those fire rings are and if maybe they got real Hot and sorta oozed/squished/grew. No clue if that is a thing but maybe some on here would know?
mag2555
Post by mag2555 »
If I hedge a bet that the motors exh valves are next to each other per cylinder would I loose?
biskma
Post by biskma »
No crushed is .047, the hoop diameter is four.10. I even have a scratch at approximately the four.05 a part of cylinder head deck and do not need to mill if don't must. Trying to convey compression down as well.
192.168.100.1 192.168.1.1
allencr267
Post by allencr267 »
mag2555 wrote: Tue Apr 16, 2024 5:10 pm If I hedge a bet that the motors exh valves are next to each other per cylinder would I loose?
Lose.
Fiat 124 Twin Cam, Hemi head, 2nd ever belt drive after the Pontiac OHC 6.
It might be the pics, but to me it sure looks like there's overhang in the cylinder and/or chamber.
rfoll
Post by rfoll »
Those motors are notorious for blowing head gaskets.
Nut124
Post by Nut124 »
allencr267 wrote: Wed Apr 17, 2024 8:29 am
Lose.
What do you mean with overhang? Fire rings too small for the bore?
allencr267
Yes.
The pic looks like the ring has upturned edges & curled back, like it was exposed to detonation while not compressed fully in contact with the head & block.
The piston's head/top land will be smaller then the bore, so " Piston contact was ruled out..." still may mean that the gasket is too small & protrudes/overhangs into the bore.
Any chance a head swap has wound up with a larger chamber?
mag2555
Post by mag2555 »
Aluminum shinny balls seen on a plug is a firm indicator that two flame fronts as in knock has blasted material of the pistons and also the heads if there aluminum.
If the motor was run on leaded race fuel these shinny balls would have a purple tint to them.
