My CompCams Cam Card ECL Question
bigpoppapreston
Post by bigpoppapreston »
Hello. I ordered and received my camshaft from Comp.
I gave them these specs:
239 intake @ .050
254 exhaust @ .050
114 lobe separation
110 intake centerline
Which should work out to:
ivo 9.5
Ivc 49.5
evo 65
evc 9
However my cam card valve timing @ .050 read:
ivo 9.5
ivc 49.5
evo 64.9
evc 9.1
Which would put the lobe separation at 113.95 instead of 114 degrees Which is stamped on the end of the camshaft.
I haven't installed the cam yet, thus I haven't degreed it.
Why the apparent discrepancy with my specs?
Thanks in advance.
-Poppy
Monza355
Re: My CompCams Cam Card ECL Question
Post by Monza355 »
IF these numbers are accurate we are talking about 0.05° i wouldn’t loose any sleep about it
Tom68
Post by Tom68 »
Everything has a tolerance.
BCjohnny
Post by BCjohnny »
If the numbers are indeed accurate I'd see it more as confirmation of good QC than some kind of error
If my maths are correct you're talking 1 / 7200 of a circle, or 3 minutes, which is a very small amount and I'd guess well within tolerance
bigpoppapreston
On my previous CompCams I just never seen them put the exact precise degrees on my cam cards.
You all are correct in saying that it's in acceptable tolerance and is nothing to worry about.
-Poppy
Walter R. Malik
Post by Walter R. Malik »
5 minutes ... really?
The width of a line on a degree wheel is more than that.
Stingr69
Post by Stingr69 »
The cam card is odd and precise. I would check that cam with a wheel for sure. I assume it was a custom grind? Close to a Crane F-278-2 solid flat tappet but just a bit more exhaust timing. Cast iron exhaust manifolds maybe?
I have an old Isky cam with rounded up valve timing numbers on the card. I guess it was to avoid decimals in the spec from confusing people, but who knows?
mt-engines
Post by mt-engines »
Walter R. Malik wrote: Mon Mar 18, 2024 10:17 am 5 minutes ... really?
.05 X 60 = 3..... 3 minutes
Walter R. Malik
mt-engines wrote: Mon Mar 18, 2024 11:38 am
So ... even less, LOL.
mt-engines
Walter R. Malik wrote: Mon Mar 18, 2024 11:41 am
The tip of the pointer lol
Roundybout
Post by Roundybout »
That’s pretty close. I wonder if any perceivable difference would be even measurable on a dyno between those two specs. Probably within the margin of error to be even picked up.
cab0154
Post by cab0154 »
i wonder how close itll be to the card when you degree it.
You wont beat anyone if you do everything the same as everyone.
Tom68
Post by Tom68 »
Stingr69 wrote: Mon Mar 18, 2024 11:18 am just a bit more exhaust timing. Cast iron exhaust manifolds maybe?
Extended high RPM power band normally.
hoffman900
Post by hoffman900 »
Roundybout wrote: Mon Mar 18, 2024 1:06 pm That’s pretty close. I wonder if any perceivable difference would be even measurable on a dyno between those two specs. Probably within the margin of error to be even picked up.
I bet actual running duration changes 5-10* from spec’ed just by virtue of system flex.
-Bob
Tom Walker
Post by Tom Walker »
What you are interpreting as a "discrepancy" I would interpret as excellent quality control and probably have some doubt about its accuracy until I put a degree wheel on it.
That would require a very large diameter wheel that is extremely accurately marked to be able to read that close, also coupled with a high quality cam drive system if cam is installed in an engine.
