Toyota 3UZ engine dimensions
does anyone know the outer dimensions of these engines? deck height? block length? the bore space is 4.15" best I can research, considering a swap, the OHC heads must be pretty tall
Re: Toyota 3UZ engine dimensions
Bore pitch in mm (105.5 ~ 4.15"):
http://australiancar.reviews/3UZ-FE-eng ... 01UZ%2DFE.
https://www.lextreme.com/infiniti-q45-vs-lexus-ls400/
1UZ: Dimensions
H: 660 mm
W: 700 mm
D: 710 mm
1UZ: Dimensions
H: 660 mm
W: 700 mm
D: 710 mm
I have a 2uz in the build at the moment, I reckon they're the same dimensions, I can measure it once it's together if you want?
one of those links has the rod length at 5.75" and the stroke is 3.25" so the deck height might be a tad shorter than the SBC, I see the LS Chevy is said to be the same 28" long, don't know if that is bellhousing to front cover or what
