I do no remember what this cam was ordered for or intended to run it. It has been on my "someday" shelf for about 15 or so years.
Comp Cams CS6218/6222 Max area solid. 291 - 299 seat 264- 272 at .050 This cam is new on a heavy-duty core [I do not remember what Comp call the core, it has extra metal around the lobes at the journals.]
I have an upcoming build 355 SBC with old 340292 heads, dome piston, for drag race on Methanol. I am considering testing this for at least two reason, one, I have all the required parts and hardware on hand, two, just curious about it's performance.
Do any of you have any experience with this lobe family?
SBC solid flat tappet older lobes question
Re: SBC solid flat tappet older lobes question
I have used those lobes for a custom grind & performance was good. No dyno testing, so no figures.
It is well down on lobe lift compared to an Ultradyne/Bullet lobe
#6218. 264 @ 050, 171 @ 200, 340 lobe lift.
UD: 263 @050, 173 @ 200, 370 lobe lift.
