No more King XP bearings
I always had much difficulty to get the correct clearance even if I always buy their 3 measures (std, +0.001, -0.001), but lately I bought a digital gauge and also discovered that all the XP rod bearings are thicker 0.0005 in the middle circle and the XP main bearings are always different right side to the left side.
Obviously I checked the housings and they were perfect, but I also tried some oem bearings to compare, and just got a +/- 0.00004 out of round, that's pretty ok.
So i'm pretty tired of them and clearly "pMaxBlack, U-Groove, ExcentriX, ElliptiX, RadiaLock" do not mean "PRECISION".
Must be their coat, but nonetheless the hole's cleanliness is worrysome
Re: No more King XP bearings
Why are you measuring the thickness that way, use a ball end micrometer.
You can buy a .200 ball to clip on a micrometer for like 25$
Clevite has there problems also. You spend lot of time and effort to get housings near perfect then beat up on the crank guy for perfection and end up with a multi million dollar company selling junk!!
Coated Calico bearings and don't look back
steve c
"Pretty don't make power"
Hiya,
Unless you are running Nitro, use the standard allecular AP and let them move. Check and set clearances and go
King bearings for the win.
-Carl
-Carl
That's THE point.lance flake wrote: ↑Thu Jan 25, 2024 9:15 pm Clevite has there problems also. You spend lot of time and effort to get housings near perfect then beat up on the crank guy for perfection and end up with a multi million dollar company selling junk!!
Anyway let's turn to better bearings
They are not available for every platform, but look into the Daido bearings that Callies sells. I have had real good luck with their sizing.
Went thru this tolerance issue on a 4.6 modular Ford during COVID. Three, maybe four sets of bearings I went thru before I got a set to work with mix-n-match. Was using King and Levite.
NHRA SS/G
1970 AMC AMX - 390 4-speed
I have had less issues with King bearings then any other brand.
The XP series tri-metal bearings I have used were the most consistently made compared to other race bearings.
There cost compared to others is also much better and their available readily in std -.001 and +.001 making clearance issues easier to get with in .0002 max.
Yes we all bitch at the crank guys to get the journal sizing right but lets look at the aftermarket cranks out there.
And also look at the rods as well.
It seems that Eagle and Scat are the most common for budget builds and with that comes a tolerance.
But when you see the journals always on the low end and the rods on the tight ends of factory spec mixing bearings is common and now mix cranks and rods because of the giant sales that are posted regularly and you get rods that are on the high limit on the big end and cranks on the low side of spec.
Remember these rods are done 1000's at a time and are with in .0002" from start to finish of a run.
Same with cranks.
As far and cleanliness its the builders responsibility to make adjustments and clean burrs from oil holes and carefully measure every part of the assembly to ensure its right.
Now look at the rotating kits on the net. They all come with std bearings, every one of them and most use king bearings.
But when we get the parts in the shop we see the bearings offer much more then the needed or wanted clearance and guys complain about low oil pressure in a new engine after break in. These are the guys that never check stuff and give a bad name to an otherwise good setup.
Same with cranks.
I've found poor quality bearings from most major companies at one time or another. Including Daido.
Just makes you appreciate when they do a good job I guess. And of course a lot of very good bearings too.
But it does seem like they make bearings in big batches, so, maybe better that you figure out how to live with it one way or another, until somebody makes another batch, it could be years. Sorry to say.
EVERY brg is going to have a tolerance.
This info comes from the Sealed Power Engine brg catalogue.
350 Chev: Rod brg info:
- shaft diam 2.0992/2.1000
- vertical oil clearance 0.0012/0.0037
- housing bore 2.2247/2.2252
It is easy to see how you can get a 'tight' or 'loose' clearance if the dimensions are at the extreme end of the tolerance range.
That does mean the part is faulty if either of these conditions occurs.
