I just looked up the records of this build from 2018. The intake valves weighed 114g.Walter R. Malik wrote: ↑Fri Jan 19, 2024 6:15 pmOn an LS3 build for a customer I have used a PAC1238X installed at 1.860" with a large hydraulic roller cam using the good Johnson, (ST2126LSR), lifters with stainless valves but, that engine had .740" valve lift. Went to 8,600 RPM easily.3pedals wrote: ↑Thu Jan 18, 2024 12:15 pm I have mast small bore LS3 heads for my LSX, and the stainless intake valves I have for them are 126g (2.08"x 5/16“ x 5.45" length).
I love these heads, but the long valves are HEAVY!
How much spring pressure am I going to need, in order to control these valves at 8000rpm?
Comp cams HLO SERIES hydraulic roller lobes 13792R intake 13795R exhuast(249*/255* .613/.613 lift 116lsa)
Johnson ST2126 hydraulic lifters.
1 shop has told me I need titanium valves, along with their super light weight rockers, in order to make this work, and I think that's bullshit.
My thaughts are a pac 1237x spring set up at ~220lbs installed ~560lbs open should control the valve train, and the Johnson lifters should handle the spring pressure..... Any thoughts, opinions, experience on this would be appreciated.
The PAC 1237X would probably be OK for you at .613" valve lift.
It was a special designed intake lobe Bullet Cam 312/321 @.006" - 258/267 @.050" - 183/190 @.200" - .4309"/.4176" lobe lift - 109 separation; 1.72/1 rocker ratio.
The engine was 387 cubic inches with a tunnel ram & carburetors; 4.020" bore x 3.8120" stroke
