Tom68 wrote: ↑Sat Jan 27, 2024 11:31 pm
HQM383 wrote: ↑Sat Jan 27, 2024 11:25 pm
You advance ICL 4° then you advance overlap triangle - or equal lift 4°. Straight up is even lift @ tdc.
Yer but your overlap triangle isn't straight up with a dual pattern cam. 4 degrees TDC overlap TDC isn't a 4 degree intake cl advance.
Straight up is ... even lift at (overlap TDC) ONLY if you have a single pattern lobe that is symmetrical above that amount of lift.
So the variables in positioning overlap triangle @ 4* BTDC puts that out of the equation to Wesman07’s original question:
This may be an elementary question but I never got a straight answer on this. Why do cam makers recommend installing 4 degrees advanced?
As this would only be in relation to icl (maybe I’m just getting on the same page as you Tom)
Here is UDHarold answering the same question as this thread original post on another forum in 2004
I don't want them installed ANOTHER 4 to 6 advanced. I just want to make sure they are where they are supposed to be. When cams are installed, there are a number of errors that add and subtract degrees from where the cam should be installed. How the piston manufacter placed the dome and where the piston pin is actually located, how close the crank throws are actually to 90°, and how accurately was the crank key-way cut, how accurately was the timing chain, etc made, dah-de-dah-de-dah......
The only thing important is the relationship between the cam and the piston, none of these other 'errors' are important, as long as the cam is in the correct relationship to the piston. In all the cam-loop testing we have done, from 151 Pontiacs through 555 BBCs, maximum BHP and torque was achieved most often at 6° advanced from straight-up, ie---106 ICL on 112 LSA, 99 ICL on 105 LSA..... Sometimes, depending upon your individual cylinder head, 4° advanced was best. The difference was always only about 4 or 5 BHP, 5 to 8 ftlbs torque.
Lunati grinds all their cams 4° advanced, because all of the core companies, who make the cores, now provide the cores with a 4° advance off the pin........
Sorry about the confusiion....
Mike, Hello, and thanks for your support. It's always nice to have to have friends....
Say hello to the wolves for me....
UDHarold
Actually, my cam cards have NEVER said to advance a cam 4°, or 6°. What they tell is what the cam's LSA is, and WHERE to place the Intake CenterLine for BEST overall power. That point is 6° advanced from where the LSA is ground. The catch is core manufacturers changed their pin offset several years ago, and instead of offering cores with a 2° offset, they changed to 4° offset, because most cams liked that better. Because of all the various possible errors, which I mentioned in a previous post, there is no way I can, or any manufacturer, gaurantee that putting a cam in and not checking it means it is exactly where it is supposed to be. We almost all grind the cam with NO advance, the lobes are advanced in relation to the pin. This way we maximize heat-treat on the lobes. To grind extra advance into the cam lobes is to take heat-treated metal off the back side of the lobes......
I told people for years to put cams in using the 4° advance key, because with the 2° pin off-set and the 4° advance, the cam would PROBABLY be around 6° advanced. It is the job of the engine builder to verify that the cam is where the cam manufacturer suggests it to be. Putting a cam with 4° advance pin-offset in 'Dot-to-Dot' means the cam is probably between 3° to 5° advanced, and possibly 2° to 6° advanced. All numbers are possible, and this does not mean that your cam was mis-ground. What it means is that it is your job to make sure the intake CenterLine is as close to the recommended position as you can get it. Almost all cams tolerate a +/- 1° in Intake Centerline position........
Does this make anything clearer?
UDHarold
Jim,
Exactly where each cam likes to run is according to how it was designed. Just because some cams are all 300° at .020 and 264° at .050 does not mean they will all run alike. Most of my most popular roller cams have at least 3 distinct LSA at .020, .050, and max lobe lift. The 2 most popular families, the 288/296R and the 310/314R, are 1.5° retarded at .050 from the nose LSA, and 3° retarded at .020,--- ie, 100° ATDC at the nose equals 101.5° ATDC at .050, and 103° ATDC at .020. All these numbers are correct, and this is the reason I tell customers to degree them in off the nose. It's easier to find, and is very accurate. The other numbers are then there automatically.
Symmetrical cams ALWAYS make more top-end power when retarded a few degrees, because the intake opens later, putting in less reversion (Heard this before?), and shuts later, allowing more cylinder filling(Heard this part,too?). I just always designed the retard at low-lift into the design.
Generally speaking, whosever cam you have, follow their general instructions on installing the cam. This is only put you into the ballpark for the ultimate power from that cam. Once you have achieved your best times, playing with the lash will determine whether or not to advance or retard the cam, and that can determine whether or not you need a larger or a smaller cam.
Good Luck, and Happy New Year!
UDHarold
I’m a Street/Strip guy..... like to think outside the quadrilateral parallelogram.
