383 SBC Acceptable Cam to Rod Clearance
- New Member
What is an acceptable cam to rod clearance on a 383 SBC stroker ?
Matt
Re: 383 SBC Acceptable Cam to Rod Clearance
Guess....20 thou clearance should never hit, bit of clearance so splash oil can get past etc, 60 thou. But I'm guessing, my first stroker is still awaiting mock assembly.
I have run 30 thou with no issue.SlowMalibu wrote: ↑Sat Jan 13, 2024 12:18 am What is an acceptable cam to rod clearance on a 383 SBC stroker ?
I like using a thin piece of solder and turning engine over by hand.
steve c
"Pretty don't make power"
- New Member
Ok, that makes me feel better, I have used a 55 thou zip tie and it clears with few thou to spare
Matt
