Chevy 193 Swirl port Mission Impossible
F-BIRD'88
Re: Chevy 193 Swirl port Mission Impossible
Post by F-BIRD'88 »
Time for some epoxy.
Any new baby pictures?
Tuner
Post by Tuner »
When is this deal going to fire up and run?
juuhanaa
Post by juuhanaa »
Bolt the Victor jr tall manifold to it and hit it with a dykem?
-juhana
A balanced person dares to stagger, and modify ports bigger
Carnut1
Post by Carnut1 »
F-BIRD'88 wrote: Wed Dec 20, 2023 10:05 pm Time for some epoxy.
No new pics, plugging along.
Carnut1
Post by Carnut1 »
Tuner wrote: Wed Dec 20, 2023 10:57 pm When is this deal going to fire up and run?
Still gathering parts and figuring port designs. All we have gotten is a good 400 2 bolt block so far. Thanks
Carnut1
Post by Carnut1 »
juuhanaa wrote: Thu Dec 21, 2023 2:16 am Bolt the Victor jr tall manifold to it and hit it with a dykem?
-juhana
On my list, stay tuned. Thanks
F-BIRD'88
Post by F-BIRD'88 »
Kinda , sorta now look like the port form of the 305 vortec head intake ports. #059 castings.
Impressive work.
1980RS
Post by 1980RS »
I was talking with a race friend about this the other night, he told me he used some set of swirl port heads. After removing the swirl ramp, widening the pinch and port match the head poured 200cc's. He ran them on a 400 SBC in his drag car running 10.50's not sure what he had for a cam and all that, but I thought that was interesting and must have been a lot of grinding.
juuhanaa
Post by juuhanaa »
Chevy 193 Swirl port cylinder heads, 27th add Edelbrock Performer Rpm Quadrajet intake. Bigger ex.
https://youtu.be/MOfMaRBKYzc?feature=shared
Will this be carburetor or efi and is there a hood clearance to consider?
-juhana
vortecpro
Post by vortecpro »
Is all the wet flow mainly about not wetting the plug?
BLSTIC
Post by BLSTIC »
Are these heads good for forced induction? I can't help but think that with their super fast burn speed you could match it to a pair of small twin scroll turbos and be able to run comparatively high levels of boost on pump gas. Would make for a great truck motor that some of you 'Muricans say you want
Carnut1
Post by Carnut1 »
juuhanaa wrote: Mon Dec 25, 2023 5:31 am Chevy 193 Swirl port cylinder heads, 27th add Edelbrock Performer Rpm Quadrajet intake. Bigger ex.
I like fuel injection and Stevie likes carbs so we will see how it progresses. Thanks
-juhana
Carnut1
Post by Carnut1 »
vortecpro wrote: Mon Dec 25, 2023 3:01 pm Is all the wet flow mainly about not wetting the plug?
Plug wetting is obviously important. What I do with the dykem is try to spead out the pattern. It is much heavier than fuel so I figure if the dykem is wide there the fuel pattern will be better. Thanks
juuhanaa
Post by juuhanaa »
I use a mix of AnreiB-Fluid and alcohol, but i found the density of Dykem in its safety data sheet;
32375.pdf
LPG 0.525 to 0.580 20%-30%
Butyl Acetate 0.882 20%-30%
Ethanol 0.789 30%-40%
= 0.746 if i calculated correctly, the specific gravity is not much heavier than the fuel. I use acetone to clean up residue between tests.
-juhana
1980RS
Post by 1980RS »
Most impressed with the OP's videos. Would love to see a test with his Vic Jr. tall vs an RPM air gap with the divider cut down. One thing for sure is, just because it's down on the flow with the flow bench doesn't mean it will be bad at the track. Still very very good numbers out of that head.
