Exhaust sizing race car
richiev88
Post by richiev88 »
Hello,
I own a 70 Camaro road race car. Its running a 572cu BBC, made 700 RWHP on dyno
(afr 357 cnc, 278/282 @50, 110, .0720 lift, 11.5.1 compression, pro systems 1180cfm carb)
Currently it has 2 1/8 primary tubes into a 3.5 inch collectors. Then 3.5 inch mandrel bent tube to a Flowmaster dual inlet 3.5 inch race muffler.
It feels like it may be restricted at its top end ( 6400rpm)
4 inch would be better, but more difficult to keep under noise limits and we have restricted space
do I need 4 inch system ??
Cheers Richie
bob460
Re: Exhaust sizing race car
Post by bob460 »
richiev88 wrote: Tue Oct 31, 2023 3:13 pm Hello,
Cheers Richie
Well the new 632ci crate engine made 840hp at the rears with a 3 inch exhaust, maybe look at some better mufflers.
Moparboy440
Post by Moparboy440 »
malibuguy79
Post by malibuguy79 »
What model flowmaster? I do not recall any dual 3.5 inlet Flowmaster mufflers.
skinny z
Post by skinny z »
Cheers Richie
Somewhere it was suggested that about 2.2 CFM per HP is required before the exhaust starts to diminish output. The gains are marginal at the top end of the scale.
Although 700 rear wheel might be be difficult to reconcile to engine HP, call it a 20% drivetrain loss. Based on that, engine output could be 840. So, following that guideline, 1680 CFM is required.
As mentioned, gains are small at the top end (as in percentage lost) but even at 1500 CFM, there are only a few mufflers that could flow that much. And I would think that the Db's are through the roof.
Is there room for two?
Combine that with Moparboy440's post regarding pipe diameter and potential CFM...
The rest is math. And packaging.
Kevin
richiev8
Post by richiev8 »
richiev8
Post by richiev8 »
Thanks for the reply’s,
Muffler is as the picture posted
I’ll drop the exhaust at the header flanges, see what changes next time on the dyno
From the tables supplied the muffler could be choke point
richiev8
Post by richiev8 »
Tom68
Post by Tom68 »
Good luck keeping the flat muffler together.
Twin 3.5" should be enough, chassis dyno with some turn downs on the collectors and see.
So much going on, pinion angle, fuel line heat shield, traction bars, rear antiroll bar with leaf springs, is power the only problem ?
richiev8
Post by richiev8 »
Why would the flat muffler be a problem? I’ve run one for 5 seasons no issue , just not with this motor.
Everything else works fine,all necessary for turning corners
I see u are AU, sometimes we run with your Tourning car masters series
skinny z
Post by skinny z »
richiev8 wrote: Thu Nov 16, 2023 10:55 pm Thanks for the reply’s,
Don't forget that by opening the exhaust at the collectors, you'll change the tuned length.
That in itself would affect the dyno results.
Have you determined what the optimum collector length should be for a mufflerless system and your application? Or what the overall length should be including the mufflers for best torque or HP?
Kevin
Tom68
Post by Tom68 »
richiev8 wrote: Fri Nov 17, 2023 2:34 pm Why would the flat muffler be a problem? I’ve run one for 5 seasons no issue , just not with this motor.
Normally hard to keep flat mufflers from cracking, but if they're working for you that's good.
richiev8
Post by richiev8 »
No issue with the mild steel ones as long as you mount them correctly, seen stainless ones split the seems
Rick!
Post by Rick! »
Maybe borescope the muffler to see if it is buggered up inside or a baffle has come apart.
I'm with Tom68 on the pinion angle. With multi-leafs and cal-tracs on an f-body set up for road racing, there isn't much droop when jacked up or much jounce when on its tires. Here's a quick measurement using Solidworks on the pic - the perspective may be making look worse but it shouldn't be off much. A quick check wouldn't hurt.
richiev8
Post by richiev8 »
Rick! wrote: Sat Nov 18, 2023 10:07 am Maybe borescope the muffler to see if it is buggered up inside or a baffle has come apart.
It’s ok inside.
Pinion is 2.5 down . Car was originally built for a historic class which limited suspension mods. Springs used to wrap up under hard braking to the point of nearly binding the uj
Running in a different class with a lot more freedoms now, so slowly working through new mods
Under rider bars are solid fabricated ones , think cal tracks slide ?
I’ve attached a pic of the set up some of our cars run, it’s a F body too.
