Speedmaster block Quality in 2023
Mpcoluv
Post by Mpcoluv »
Guys,
I know speedmaster hired one of the Edelbrock engineers a while back. Are their blocks now usable?
Chris_Hamilton
Re: Speedmaster block Quality in 2023
Post by Chris_Hamilton »
Mpcoluv wrote: Wed Sep 27, 2023 8:41 pm Guys,
If this is the one I'm thinking of, Speedmaster lied about hiring him. Guy said as much. I think he consulted on something, but was never an employee or did anything for them long term. It's in a thread here somewhere. Can't point you to it though without searching.
High quality metal, body and paint work
http://www.spiuserforum.com/index.php?t ... inia.9030/
Chris_Hamilton
viewtopic.php?t=64918
Makes me really not want to use anything of theirs. If they will lie about this what does that say?
Walter R. Malik
Post by Walter R. Malik »
Chris_Hamilton wrote: Wed Sep 27, 2023 9:10 pm viewtopic.php?t=64918
I will use only a few things from them ... nothing with moving parts.
Big bald guy
Post by Big bald guy »
Customer brought me all the parts to build two marine engines. Speedmaster rods, same part number, 40 grams difference from set to set. I refuse to use anything from them.
BOOT
Post by BOOT »
Speedmaster is much worse than any generic ebay/amazon overseas stuff. Prob worse than counterfeit stuff too!
BOOT
Post by BOOT »
Walter R. Malik wrote: Thu Sep 28, 2023 10:12 am I will use only a few things from them ... nothing with moving parts.
Or electrical :lol:
Caprimaniac
Post by Caprimaniac »
Even if the block ain’t moving by itslef I would never consider one. I once did, but after figuring out all the issues…
But you never know, everyone can change into something better- or worse.
BOOT
Post by BOOT »
Caprimaniac wrote: Fri Sep 29, 2023 11:11 am
I think he means stuff like spacers, block off plates or bits n pieces. Things they can't screw up too bad or is easily fixed. I'd only used thier block if i was a machinist and had plenty of free time, for my own personal use.
Racer97
Post by Racer97 »
I've used camshafts timing covers and valves from them with no problems. Cams were hydraulic roller.
FC-Pilot
Post by FC-Pilot »
It’s hit or miss. I have thrown away timing covers where holes were off so bad they could not stop leaking. I have used intakes knowing I would have to true up surfaces. Have had luck with stainless shaft rockers after fixing the stands. Also trashed some that were too screwed up to fix. A friend brought me one of their carbs, all I can say was wow! I pieced one out of shelf junk I had. I plan on making it work but there was no hope with its original boosters. I will use stuff from them when I am ready to fix it to use and even with the fix time and cost I will come out on top. Heads are hit and miss. Have had issues with the seats flaking apart, valve guides wearing out quickly even when rocker geometry was checked. I have used many of their carb spacers and will again.
Paul
bthomas
Post by bthomas »
I recently picked up their double adjustable pushrod length checker. It looked like a nice piece with a super wide adjustment range. Turns out it was .040 off.
I set the length to match a pushrod with a 12” caliper. So checker and pushrod both measure the same oal. Actual pushrod had .040 more preload. Only thing I can figure is the ball end radius has to be different where it actually sits in cup.
FC-Pilot
Post by FC-Pilot »
Their stuff is under engineered. If you have the patience to work round it, then fine.
I don’t go to Taco Bell and order fillet minion and complain when it tastes like a chalupa. Sadly marketing has convinced the low buck or uneducated that they can have top notch stuff for peanut.
Paul
smokie
Post by smokie »
They can't even get a set of valve covers to fit without reaming out at least one hole. After 20 years of them selling junk, you would think people would learn.
BOOT
Post by BOOT »
FC-Pilot wrote: Fri Sep 29, 2023 4:46 pm Their stuff is under engineered. If you have the patience to work round it, then fine.
Their stuff is rejects china don't sell LOL i got several ebay intakes & other stuff but the speedmaster https://youtu.be/LKv6dRNbELM , is the worst I've seen n i sent back 3 Holley intakes.
