Old School wrote:I am assembling a 454 BBC that will be a street engine and raced on grudge night at the local strip. With the piston rocked so the quench side is at the highest the outer most edge of the piston deck is .007 out of the cylinder. With the piston rocked so the quench is at its lowest the piston deck is .005 in the cylinder.
I was wanting to use a .039 gasket but now I am not so sure. The max rpm's will be 6500. The car has an excellent cooling system. Rods are Scat H beams. Rod clearance is .0028. Piston to wall clearance is .008. I know that is too much but you use what you have in some cases.
I was wanting the increased benefits of a tight quench. I do not want the problems of a piston hitting the head. Should I just put a .051 gasket on and play it safe. Compression will be 10.5 with the .039 and roughly 10.25 with the .051? The pistons have been coated so that rules out milling a few thousands off the quench.
Thanks for any help.
bigjoe1 wrote:My experience is that you still get all the same bennifits of the tight quinch with up to 050 or 055. There is NO reason to take a chance with hitting the head because it will work just as well with 005 or 010 more room.
JOE SHERMAN RACING
Users browsing this forum: Baprace, GregGood, racerx1622, SKeown, Sprinter99 and 4 guests
