Couldn't find any pics from sides or ends ,but this was cut down 1-1/8" on runners. Ported a ton to get taper working for rpm. Had 1-1/8th " plenum spacer and we ran rubber mounted anti reversion plates from Braswell iirc. My brother found time slips from his old victor ram that I welded runners and plated. Had 585" plenum in it also. It was over a tenth faster on his engine than the pro failure otbprofiler tunnel ram
Re: profiler tunnel ram
Made 3 passes. I'm sure i was making way more power but couldn't get a clean pass then on the 3 rd run hit the wall.
My 60 foot was on track to be my best ever run. Came off the line heading towards the center. I don't know what happened but i hit the wall just before the 1/8 mile timers. There is lots of video out there i will try and find.
I'm ok just a bit beat up. There was probably 5000 people watching so its gonna be hard to keep it a secret.
The car is destroyed.
Brian
Brian
- Dave Koehler
Glad you are ok. That is going to take considerable buffing.
Brian
We took our intake off before we crushed it.
That sucks a bunch,always hate to see a guy have a wreck . I'm glad you are not seriously hurt. I hope you can get back going again! Take care.
Wow.. sorry to read about the car, but glad to read you're ok.prairiehotrodder wrote: ↑Sun Aug 20, 2023 12:20 pm Made 3 passes. I'm sure i was making way more power but couldn't get a clean pass then on the 3 rd run hit the wall.
Brian
Ouch. Happy to read that you're OK though.prairiehotrodder wrote: ↑Sun Aug 20, 2023 12:20 pm I'm ok just a bit beat up. There was probably 5000 people watching so its gonna be hard to keep it a secret.
You'll be back!
Kevin
Prairiehotrodder, I know you are very disappointed as any of us would be also if we were in your shoes, but i know that you are thanking the good Lord that you are ok. Write on the shop wall " Build Back Better " what do ya think . Mark H.
So sorry to see this. I am so glad you are ok. The only thing worse than seeing a wreck is watching someone get hurt. Thank the Lord the car did its job and the man up stairs for looking out for you.
Paul
Paul
don't know how to post a video. Don't want to put it on yuotube.
glad you are ok and sucks it wrecked.
79 Cmaro, 427 sbc, Tunnel Ram Dual Quad with Eddy carbs, AFR 210 Race Ready heads, 263-272 @.50 Comp solid roller cam, 4.10's and a faceplated Tremec TKO 600.
65 Beaumont 406 tunnel ram faceplated TKO600
You should be able to upload it from a saved file on your computer provided it's the correct format and no larger than 10 MB.prairiehotrodder wrote: ↑Mon Aug 21, 2023 11:44 am don't know how to post a video. Don't want to put it on yuotube.
From the FAQs page:
[i]What attachments are allowed on this board?
Each board administrator can allow or disallow certain attachment types. If you are unsure what is allowed to be uploaded, contact the board administrator for assistance.[/i]
Kevin
I'm asking Mike how to post a video.
Seeing as you're OK, I suppose it's alright to ask if the drivetrain took a hit too. I've broken a transmission case and bent a rear axle with a similar impact. Although rather than a guardrail it was a hillside adjacent to the road when I spun around on poor tires in the rain. Crunched my 68 Chevelle in the left rear quarter and then the culvert wiped out the front end. That was a lot of years ago (40+) but I remember the incident with unusual clarity.
Kevin
yes the transmission is broken, engine looks ok though one carb has a broken piece not to serious.
Dang!
Awesome hobby at times isn't it?
I had an engine failure a few years back. A little thing that led to destruction (or very nearly so). I've been in the planning/rebuilding phase ever since. But the end is in sight. Here's hoping you can get back at it sooner rather than later.
Kevin
