The amplifier head on my Stewart-Warner crank balancer is starting to get flaky again. It cost $600 to get it repaired last time. I'm thinking it might be time to move up from 1970 analog electronics.
I thought I'd seen some PC-based upgrades for the old SW balancers somewhere, but now I can't seem to find anything in my piles of "stuff."
Has anyone seen a digital upgrade for the SW lately?
Stewart-Warner balancer upgrade?
stewart warner upgrade
Call Gary at GH balancer service 773-509-1988. He is the GO TO Guy for anything to do with a stewart warner rig. He should know first hand if any upgrades are available.
James Baldwin
USA RACING ENGINES / THE WOP SHOP
713-645-4000
713-645-4000
Stewart-Warner balancer upgrade.
I might be late with this post. I also have a Stewart-Balancer and Gary Hildreth of GH Balancing is the Man. He was the chief engineer at Stewart-Warner. I think he is the only one who services these machines. He has helped me with my machine quite a few times. I'm pretty sure he has all the necessary components to repair or upgrade your machine.
GH is well known for keeping the old machines in service.
What I expect dwilliams is looking for is an electronic conversion or upgrade.
Most companie$ make money convincing you to buy an entire machine.
It would not be very difficult to put something together with current data acquisition. And retain the SW frame.
Making the world a better place... one pair of heads at a time.
The true spirit of conversation consists in building on another man's observation, not overturning it.
Edward Bulwer-lytton
- New Member
Re: Stewart-Warner balancer upgrade?
I'm currently repairing a Jackson & Bradwell machine of similar generation. I don't know if you have the same coupler pickup, but this uses two leaf spring pickups effectively (one per axis) and these are metal-foil gauged in a half Wheatstone bridge config per spring. On this machine the gages have gone noisy, and it may well be similar on yours? I'm going to replace the gages and go from there.dwilliams wrote:The amplifier head on my Stewart-Warner crank balancer is starting to get flaky again.
"The difference between what we are... and what we want to be... is what we do"
- Wolfplace
=dwilliams wrote:The amplifier head on my Stewart-Warner crank balancer is starting to get flaky again. It cost $600 to get it repaired last time. I'm thinking it might be time to move up from 1970 analog electronics.
Contact T&S Machine
I was talking to them a couple of weeks ago & he was telling me about a PC based upgrade for the Winnona & I believe he said he can do any older analog machine
http://www.tnsmachines.com/default.htm
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
A tour of my shop
The Dyno
John Wayne
How are my gauges going, Martin?Martin Faulks wrote:I'm currently repairing a Jackson & Bradwell machine of similar generation. I don't know if you have the same coupler pickup, but this uses two leaf spring pickups effectively (one per axis) and these are metal-foil gauged in a half Wheatstone bridge config per spring. On this machine the gages have gone noisy, and it may well be similar on yours? I'm going to replace the gages and go from there.dwilliams wrote:The amplifier head on my Stewart-Warner crank balancer is starting to get flaky again.
The cermet thingy should be here this week, sometime.
Welcome to the forum.
John.
- New Member
Hi John,
Thanks for the welcome. Yes good news have re-gaged your springs, will be interesting to see if the new gage grid area / possible change in gage factor will upset things, but guess we will have to suck-it and see. There will be a number of possible options if so: change the amplifier gain, or the amount of spring pre-load. The only issue I can see there (if gage factor is higher than the originals), will be running out of pre-load deflection if you like with a -ve displacement. This will cause the spring to go past the null position and cause linearity issues- or translated into giving the incorrect weight adjustment indication, and possibly the wrong sign John I think you will be the only guy in town always adding weight Joke!! Don't worry will calibrate out one way or the other, been doing it for years for Schaevitz
