Oil pan gasket 434 SBC
Re: Oil pan gasket 434 SBC
Same question,in what application? Drag or endurance? Both? I have no experience with anything endurance other than the red and copper in a N/A use.
It is a 79 Bronco with a 605 A head engine. Sand dune truck that sees street driving any chance i get.
Maddog headers and full exhaust.
I couldn't stand how the copper looked and noticed the new grey is good for a decent amount of heat so i figured i wouldn't be out anything but time if it didn't work.
Works great and looks way better, coated headers and aluminum heads it blends right in.
- mt-engines
Hiya's,
The Victor Reinz has aluminum in it and moves with temp. Peels right off the pan rails and doesn't leak. Amazing stuff. Try it
https://victorreinz.us/products/reinzosil-rtv-silicone
-Carl
-Carl
I would like to add a comment to this thread. The very last thing to touch the surfaces that " Any " sealing product is going to bond to should be a
Clean / Unused lint free paper towel soaked with Acetone, some popular products such as Brake-Clean "Will" leave a slight residue which will harm
the bonding ability to the surfaces . This may help somebody that is unaware . Mark H.
We do only want a seal though, a good bond can be detrimental to the oil pan on disassembly, especially if you have studs.swampbuggy wrote: ↑Thu Jan 04, 2024 1:44 pm I would like to add a comment to this thread. The very last thing to touch the surfaces that " Any " sealing product is going to bond to should be a
This article explains all the differences in permatex silicones.
https://4lowmagazine.com/rtv-colors-and ... -use-them/
Notice that the Permatex guy doesn't write anything about RTV sealing gaps > 0.15mm / 0.006in like the Victor R lit. does? I'd never use it on/between 2 machined surfaces and the .006 min. still seems too small to me.
It doesn't actually seal between machined surfaces, it's the bead of goop squished out along the inner & outer perimeter that does the actual sealing, so deburr/chamfer their edges or your real seal will get pinched/fall off!
