Background: BBC454 in a '71 Vette with a 5-speed Tremec behind it.
The engine specs are:
Stock LS-5 block, crank, rods.
Aluminum heads.
Hydraulic roller cam
Headers
EFI
Last fall I had the short block rebuilt due to oil consumption. Found 4 broken piston rings, huuuuuge ring gaps, uneven deck etc. Basically, whoever did the last rebuilt should be shot.
The shortblock was done by a very good machinist who has done engines for people I know for decades. The crank was OK, just needed polishing. Rods OK, resized. Went with Probe Forged pistons and 10.15:1 compression. Decked block so pistons are 0.005" down. With a 0.039" headgasket I have a 0.044" quench.
Re-used everything else (heads, cam, distributor, flywheel, clutch, etc etc). Converted the mechanical clutch to a hydraulic setup while the engine was out.
I assembled the shortblock myself with the help of a guy I trust and has done many of these before. Also, this is not the first engine I've done.
The engine fired right up, no smoke. I've put about 2000 miles on it sofar.
Now the problem: ever since the rebuild it has a very noticeable rattle. The sound is like a heat shield (thin metal) rattling against another metal object. Except I have no heat shields.
Here's were it gets weird: It never does it below 2000 rpm. It also doesn't do it under no load or very light load. I can rev it in neutral, no noise. I can drive it in 1 st, and slowly accelerate, no noise. But under some load it will start rattling at about 2300 rpm. It gets less at 2500, then comes back at 2800.
And to make it weirder: At very high load (close to WOT), it goes away.
Also: The pitch or frequency of the rattle does NOT change with rpm. It always sounds the same. There is no difference when the engine is cold or hot.
I have not been able to pinpoint the noise as it doesn't do it in neutral. It sounds to me that it is coming from the left side, and not from the top of the engine.
What I've done:
Took belts off to disconnect PS, AC and alternator. No change.
Checked exhaust system for clearance. It clears + it's the same system as before the rebuild.
Checked motor mounts.
Checked all bolts/nuts on the engine. No loose bolts found.
Checked bellhousing and tranny bolts. They're tight.
Removed bellhousing splash shield. No change.
Oil pressure is normal. 30 PSI hot idle, 50-60 PSI going down the road. Maxing out at 70 PSI. Oil is Castrol 10W-40.
HEEEELLLPP!!!
