M20 compared to M21
73c34me
M20 compared to M21
Post by 73c34me »
Hello, Would like some thoughts on this combo. I have the M20 installed and an M21 on the shelf, that i would like to try.
1973 Vette, 3100 lbs. 4.1:1 R&P. 12:1 383 Stroker motor. Issues
Upon take off, I shift into 2nd nearly after the clutch is completely out
Upshifting from 3-4 at high rpms is difficult. Downshifting at speed from 4-3 is like hitting the brakes...
I don't race the car but enjoy spirited driving and the occasional 1/4 mile test and tune.
Also, I would like the clutch to last..
thanks.
In-Tech
Vendor
Re: M20 compared to M21
Post by In-Tech »
Are the splines the same, I remember my 73 camino came with m21 and fine spline input(26 I think) and T400 large size output shaft.
-Carl
Rick!
Post by Rick! »
novadude
Post by novadude »
M21 will have a taller 1st, 2nd, 3rd gear compared to the M20, and the ratio spread from 3-4 will not be as wide as compared to a M20. With 4:11, it seems like the M21 would be a better fit in that light car. No worries about excessive clutch slipping with that much gear in the rear. The M21 should allow you to actually use 1st and not shift as soon as the clutch is out, and the tighter 3-4 spread with the M21 should help with the "hitting the brakes" feeling on a 4-3 downshift.
discloseenjoin
Post by discloseenjoin »
Rick! wrote: Sat Jan 01, 2022 7:19 am Muncie Identification Article
The information is not overly focused. I couldn't come up with a solution.
tjs44
Post by tjs44 »
For street driving I like the M20 as I could pretty much go from first to third around town driving where with the M21 you pretty much had to gothru all the gears.Tom
panic
Post by panic »
The "wide" ratio box has 2.52:1 1st gear, the "close" is 2.20:1.
"Close" only refers to the 3-4 shift, the RPM loss on the 1-2 and 2-3 shift are the same for both.
With tall (numerically low) axle, the 2.20 is a pain to drive in traffic. For a 9:1 overall SLR/crawl ratio, the close box needs 4.09 axle, the wide 3.57.
