for a race car, are there any reasonably price digital clusters that would keep track of :
engine RPM
oil pressure
coolant temp
A/F ratio
speed
Not wanting a full EFI tuning setup. Just a cluster that could be bolted to a roll cage and give me the basics. I think this might be as high tech as i ever want to go with my simple brain.
Brian
I see holley has one for $800 and autometer is about $1600
Digital gage cluster
Re: Digital gage cluster
Have you checked longacre out? Also may look into mychron, we use them on the karts and midgets
Might be cheaper to use an ipad, i know several peeps do
thanks for the reply's. I lost interest in this idea when i found out the prices start at $2000 for the basics.
- New Member
Look into innovate motorsports. Gauges are reasonably priced and you can data log then also.
