race oil
race oil
Postby mike kittrell » Sat Apr 21, 2007 9:27 pm
with all the changes to motor oil what is the best oil for a dirt late model
engine thanks mk
mike kittrell
Postby needforspeed66gt » Sun Apr 22, 2007 12:49 am
I always use Kendall GT-1
Nate Cutler
Engine Machinist
needforspeed66gt
Postby Twystd1 » Sun Apr 22, 2007 1:36 am
Brad Penn and a bottle of GM EOS.
Clayton
I know even less than you..
Twystd1
Postby CNC BLOCKS » Sun Apr 22, 2007 11:29 am
needforspeed66gt wrote:I always use Kendall GT-1
Yhats not the original Kendall GT-1 oil as the better oil is the original green oil made by Brad-penn http://www.bradpennracing.com/
http://WWW.CNCBLOCKSNE.COM
IS A DIVISION OF
HINKSON AUTOMOTIVE
RESEARCH & DEVELOPMENT
We are WD on AFR, Dart, Wiseco, JE, CP, Crower, Manley, CARRILLO, Callies, King's Crankshaft. COMP CAMS, Diamond pistons ETC.
CARL HINKSON 207-892-7215
CNC BLOCKS
Postby #84Dave » Sun Apr 22, 2007 12:20 pm
Running bearing clearances of .0025-.00275 in our Chev V-8 Super Late Model paved-oval engine, we've had great success with a 50-50 mix of Valvoline Racing 30-weight and 20W-50. Along with 2 bottles (1 quart) of GM EOS in our 12-quart dry-sump system. Others in our series also run the Brad Penn oil with good success. The GM EOS has 9000 ppm of zinc, one of nature's best anti-wear products. I personally won't put an endurance race engine on a track without the EOS added to the oil.
Dave
#84Dave
Postby needforspeed66gt » Sun Apr 22, 2007 1:46 pm
When did it change? I am on my last case, and it still pours green...
Nate Cutler
Engine Machinist
needforspeed66gt
Postby Wolfplace » Sun Apr 22, 2007 2:14 pm
About 10 years ago
Mike (Wolfplace)
VISIT US AT
Lewis Racing Engines
Complete 4axis CNC block machining
"Life is tough.,, Life is even tougher if you're stupid."
-----John Wayne-----
Wolfplace
Postby needforspeed66gt » Sun Apr 22, 2007 6:07 pm
Wolfplace wrote:
About 10 years ago
wow - glad I found out now, I was going to order a bunch more cases this week.
Nate Cutler
Engine Machinist
needforspeed66gt
Postby racer189 » Sun Apr 22, 2007 10:27 pm
Should a person consider adding EOS to synthetic oil (Joe Gibbs) in a marine endurance application.
racer189
Postby TSTOM » Sun Apr 22, 2007 11:06 pm
Brad Penn here too.... and by the way....it's still green
TSTOM
Postby #84Dave » Sun Apr 22, 2007 11:52 pm
Racer189...... if the Gibbs oil has less than about 1200-1400 ppm of zinc, I'd add EOS to bring the zinc up. Most decent racing oils will have at least 1200 ppm of zinc. At least the mineral oils. I'm not a synthetic expert, so I don't know if they substitute some other additive package for anti-wear properties in synthetics. But zinc is the anti-wear substance of choice in mineral oils. Since the government told the refineries/blenders to cut the zinc down for normal highway use oils, some oils are down to 600-880 ppm. I also don't know if the government mandated any zinc removal from pure racing oils. They may have left them alone. But EOS is cheap insurance @ ~$6 a bottle so I use it. I use it in all my race engines, even using racing mineral oil, and I dump a bottle in my personal vehicles at every oil change. I'll change the catalytic converter if it goes south, rather than take a chance on excessive engine wear. I can buy quite a few cat's for the price of replacing the engine in my S-10 Chev! Dave
#84Dave
Postby mike kittrell » Fri Apr 27, 2007 4:13 pm
thanks
mike kittrell
Race oil
Postby Ron Golden » Fri Apr 27, 2007 5:52 pm
Guys,
It seems most of the engine builders are concerned with the governments requirement that the zinc and phosphorus levels in engine oils continue to be lowered to protect catalic converters. Unknown to most of us this lowering started in 1996 and doesn't seem to have bottomed out.
Lately I've talked to the engineering departments at Red Line, Mobil 1 and Royal Purple about the amount of zinc and phosphorus in their racing oils. From what I could gleen from the conversations Mobil 1 has just over 1000 ppm of zinc and phosphorus, Royal Purple wouldn't tell me how much their oils contained and Red Line said their oils contained 2400 ppm of zinc and 2500 ppm of phosphorus.
According to the tech person at Red Line the normal mineral based oils we buy at O'Reillys, Advance Auto, etc. are now in the 400 ppm range.
It would seem flat tappet cams are destined to become a thing of the past even though some roundy-round classes still require them in an attempt to keep costs down. A lot of the owners of street driven cars still want to use flat tappet cams for the same reason since they aren't aware of the situation.
Although no final decision has been made it looks like Red Line racing oil is on the top of our list. I'll keep talking to the oil companies before a final decision is made.
Ron
Ron Golden
Postby racer189 » Sat Apr 28, 2007 12:19 am
I don't know how much Zinc Joe Gibbs Synthetic has. I heard that it was one of the best racing oils available. There probably won't be a problem but I'm a little nervous about adding EOS to synthetic oil in a $35,000+ engine without knowing it will be ok for sure.
racer189
Postby TheEngineWorks.com » Sat Apr 28, 2007 1:03 am
I use Rotella T, it still has 1500ppm of zinc and a very good anti-ware package due to it being for extreme use (diesel)..
TheEngineWorks.com
772-380-9111
08 Drag Week Pro Street winner, 7.97 @ 174
TheEngineWorks.com
Next
Return to Engine Tech
Who is online
Users browsing this forum: Sprinter99 and 10 guests
cron
