BlackoutSteve wrote:Peak oil pressure is controlled by the bypass valve, and shimming the spring only results in varying the peak pressure.
Regular operating pressure is controlled by both the amount of engine leakage verses pump volume.
Putting more volume of oil through an engine will result in a higher pressure until the pump begins to bypass.
Surely you wouldn't suggest that an 8/71 blower produces no more boost than a smaller 6/71 on the same engine with the same 1:1 drive ratio?
It does throughout the rpm range, because it's bigger. Same goes for standard verses high volume oil pumps.
My question is how much.
Q-ship wrote:You should gain exactly ZERO oil pressure increase with a HV pump if each pump (standard and HV) have the same pressure relief spring.
Fluid is non compressible, so you are only making it hard to understand oil pressure by comparing it to a blower. There is no comparison.
The oil pressure relief spring is what controls the oil pressure as it starts to compress enough to begin exposing the bypass port (back to the oil pan) at a certain pressure. A HV pump will simply pick up and return MORE oil to the pan.
The bypass spring is not an on/off switch as it uncovers more of the bypass port as the pressure increases, so it is not just a "peak" pressure controller.
You need to understand that you cannot increase volume without increasing pressure no matter how big the oil pump is. That's why High-pressure pumps have a heavy spring in them.
The only exception to this would be if you were running extreme bearing clearances or had some other "leakage" situation that the stock pump couldn't provide adequate capacity for, but considering that a stock pump is designed for about 70% more capacity than is necessary, and can burst an oil filter if the relief spring sticks, a stock pump is usually far more than adequate for all but a top fuel type engine.
My guess is that since you went to a roller cam that the lifter skirts are to short and uncovering the oil galley. That's the only reason I can think of to explain why your oil pressure changed so much with only a cam change.
In any event, if your pressure increases by changing to a HV pump, you have a serious problem somewhere else that needs to be addressed immediately.
EDIT, I just saw your other post. I have never used the lifters you are using, but I guess it is possible to bleed off enough volume to effect oil pressure considerably, however I believe you need to increase pressure to compensate (HP spring), as it is highly unlikely that a HV pump will address your problem.
Unless someone will educate me, I am not aware of any type of a working by-pass valve on any automotive oil pump? The only by-pass valve I know of is on the filter adapters or the filters and should not be on any performance engines in my opinion.
I like plently of oil pressure and plenty of volume, and don't care that a little less pressure and a little less volume would mean a few more horsepower. I recently turned back the pressure a little on a customer's freshen up becuase he was uncomoftable with the high oil pressure. I love it myself. He was idling at 60 psi and burying the neddle when he bliped the throttle cold. Hot it still idled at 60 psi (1200 rpm) and went to 100 psi whet it was hot. After me cranking down his pressure it is still idling at 60 psi but only climbs to 85 psi hot. I think next time it comes back I will crank it up a little more.
Users browsing this forum: Baprace, GregGood, racerx1622, SKeown, Sprinter99 and 4 guests
