Lower the engine and move it back until the head’s almost hit the firewall. That is of course if it’s not that way already.SpeierRacingHeads wrote: ↑Wed Feb 21, 2024 11:51 amI had 150+ hrs in my personal Super Stock heads and manifold. I did the engine myself and everything was 100% new and it's far from Super "Stock"..RW TECH wrote: ↑Wed Feb 21, 2024 11:15 amI would certainly argue that a good super stock engine is more labor intensive and complex then building a cup engine or for that matter even maybe a Pro Stock engine. If there is a slight chance of a minimal gain in stock or super stock you have to take the opportunity, and more often than not the opportunities do not live under the hood.
I have the car on scales right now and it presents it's own problems. 55% weight on the front. I've spent $5K just on the car to the latest cool stuff.
A 2002 Cavalier with TH200 and aluminum headed SBC weighs 2490 without driver.
NHRA STOCK valve job
Re: NHRA STOCK valve job
Stocker valve job can be any angle and as many angles as you want with bowl blending down to the top of the guide boss.
It’s a front wheel drive lol
It is not necessary to build a swimming pool to determine that a bowling ball won't float." .....Zora Arkus-Duntov www.facebook.com/COMP461
Ummmm. I think it's an Eastexas car, as in FWD conversion. And you raced Comp????
No it’s a 1984 Dodge Daytona 2.2 turbo. I ran a D/ED and C/ED in comp and SS/DM in SS.
I got it as low as I could. Still has a 16" cam center. But I have to add weight so I will get it ironed out.
