Ken_Parkman wrote:man"]This is a topic I have been researching lately. I have the advantage of working at a place where one of the foremost experts on engine dynamics is - unfortunately it's aircraft turbine engines. But we talked about theory as applied to a piston engine. I can hopefully add some info as to the theory of all this, I'm wondering if there is some experience that backs up the theory.
The problem is every component no matter what it is has natural frequencies built into it, and if there is an exciting force at one of these frequencies this can be disasterous. This industry has taught me tremendous respect for vibration. So as applied to a crankshaft here goes: The crank assembly has a frequency at which it wants to torsionally vibrate. When the engine is operated at a speed where the frequency of the cylinders firing (exciting force) corresponds to the crankshaft assembly natural frequency the crank can go into a torsional vibration, and if the rpm dwells at this point long enough bad things start to happen. My experience has been the first sign of this is timing chain stretch, progressing on to cracked cranks, then to complete failure. My opinion is if (big if) you have excitation of a natural frequency the HCF stress generated can be astronomical. I can back this up a bit with some strain gage work we were doing chasing an engine casing failure. This was on a nickel superalloy case that was cracking in an area that technically had no load. Once we found the exciting frequencey we found vibratory stress that defied belief. This superalloy that was not carrying any load would only last seconds when we ran the engine at the exact right speed.
The natural frequency is a function of crankshaft assembly polar moment of inertia and stiffness, the stiffer the crank the higher the frequency, the heavier the component in the assembly, especially the flywheel, the lower the frequency. Dampers are either amplitude or frequency sensitive (the pendulum style has been used in aircraft piston engines and does work, I have not figured out how yet) I have always liked the amplitude sensitive style like the Fisher as it is independant of the frequency, but due to other reasons I will no longer deal with them. The frequncy sensitive design is theoretically more ideal if tuned correctly, but this is my problem - how do you tune it? I know eqipment exists to do this, but it is way beyond my resources. Do the high end Nascar guys do this tuning with the ATI? And I would think if you changed the flyweel for example this style damper would need to change.
I'm wondering if this is how the sprint car guys can survive with no damper at all. Maybe the light crank and especially the no flywheel pushes the frequency above the point where the engine rpm can reach, therefore there is no exciting force, therefore no need for a damper at all. My dynamics buddy (who knows nothing about piston engines) figures from our conversation that the flywheel is the most important of the assembly from a frequency point of view cause of it's large diameter. Has anyone ever looked into stuff like this?[/i]
Users browsing this forum: Baprace, Sprinter99 and 5 guests
