maxracesoftware wrote:i usually stay far away from a TQ -vs- HP Post
what gives you the potential and ability to run the fastest
in any MotorSports form is = (Torque times RPM) which is HorsePower
..for Professional max-effort applications=
you want the greatest amount of Torque
at the highest RPM you can achieve
(which is HorsePower)
just a quick look at Formula 1, NASCAR, ProStock....
RPMs are increasing ...no one's going the opposite way to lower RPMs.
Formula 1 + NASCAR + ProStock should all be capable of
achieving the same peak Torque at much lower RPMs if they wanted to.
Example, Formula 1 could achieve same peak Torque at 5000-6000
or less if they desired to ....but instead move the same amount Torque
to 16,000+ RPM .
another example
600 Lbs Torque @ 5000 RPM = 571.2 HP
600 Lbs Torque @ 9000 RPM = 1028.2 HP gains = +457 HP
its pretty obvious how important (Torque times RPM) = HP,
is !!! .... i'm certain you won't see any Formula 1 engine being designed
to run 5000 rpm or less, likewise NASCAR or ProStockers,
instead they'll all keeping searching for ways
to move their Torque Curves higher and higher
to achieve more HP which is just TQ times RPM.
Robert Kane wrote:Thank you, thank you, thank you, Larry and Darin. I have been growing hoarse discussing this point for years. I say if I have a bucket that hold 5 gallons (representing torque) and I can carry 4 buckets (representing RPM) and my brother also has 5 gallon buckets (same torque) but only carries 3 of them in the same amount of time, (lower RPM) then I have done 33% more work, or have accelerated more mass in the same time ( or same mass in less time - lower e.t.).
In fact you can run faster/ lower e.t. with more RPM and less flywheel torque and apply more wheel torque with proper gearing. Get me through the RPM's and into high gear as quick as possible and let my final ratio picked for best acceleration through high gear. If it's lazy in high gear it's never gonna run the numbers.
Now a jet drag boat is a different animal.
Robert
Users browsing this forum: crumple, Sprinter99, Yahoo [Bot] and 10 guests
