machine shop tom wrote:I don't usually recommend K/B or Silvolite claimer hypers mainly 'cause there are too many pitfalls awaiting the "on the ragged edge" guy or the careless tuner.
KB is serious about the extra gap on the top ring. But even experience engine builders often fail to read the directions, and they wind up with a piston that looks like the one in the little booklet that comes in every box of KB pistons, that shows a piston with the top ring land ripped off. I have one sitting on the shelf, that I picked out of another shop's scrap bin.
"Damned junk, that's what usually happens with those things."
"Did you file the extra clearance into the ring gap?"
"What? I can't waste time with that."
I've also seen people fail to notch the oil ring for the dowel pin for the pistons that bridge the lower rail across the pin bore. They'll make two or three attempts to jam the piston into the hole, then line the gap on on the dowel. That doesn't work very well either...
These are usually the same guys who hate Spirolox, because they never read the instructions on how to install them.
As they say, "RTFM."
