350 TBI tows 5000/6000lbs
user-30257
Re: 350 TBI tows 5000/6000lbs
Post by user-30257 »
donforeman wrote: Wed Jun 06, 2018 9:37 pm Thank you for the replies. The truck I was looking at has some overheating issues that were not mentioned in the ad. So I am back to looking at want ads. Yes the van does fine if you slow down, but you cant do that too much or you become a traffic hazard. The 4l60e was rebuilt by me with all the towing upgrades, so who knows how long it will last. Its no 4l80e though. I took down the pan last week and it was spotless inside even after towing pretty often for the last few months.
Someone already mentioned what you need. A cam, springs, converter and trans cooler. Don't be afraid to give the engine rpm on the hills. It's betterb than lugging it in overdrive trying to great a mountain. Simply downshift it and let her sing 4k rpm isn't a big deal.
donforeman
Post by donforeman »
I never tow in OD with the 4l60e. Like I wrote before 3rd and 2nd are the gears I use when towing. I did purchase a take out 14097395 roller cam (196/206@109) from a marine engine for the van in case the block happens to be roller comparable. If its not then, I will figure something else out and I can get rid of the roller cam easy for what I gave for it.
user-30257
donforeman wrote: Thu Jun 07, 2018 1:44 am I never tow in OD with the 4l60e. Like I wrote before 3rd and 2nd are the gears I use when towing. I did purchase a take out 14097395 roller cam (196/206@109) from a marine engine for the van in case the block happens to be roller comparable. If its not then, I will figure something else out and I can get rid of the roller cam easy for what I gave for it.
I wasn't trying to say you do. But many guys think they need the power to do so.
jeff swisher
Post by jeff swisher »
You can run that roller cam in a non roller block just do the retainer plate modification if it is a stepped nose cam.
That may be a dandy cam for the purpose.
77cruiser
Post by 77cruiser »
FWIW the 95 I had was roller compatible but it had a flat tappet hyd. in it. It was a 1500 Sierra.
Jim
donforeman
77cruiser wrote: Thu Jun 07, 2018 10:16 am FWIW the 95 I had was roller compatible but it had a flat tappet hyd. in it. It was a 1500 Sierra.
Thanks for all the help.
TBI Chips lists the 94-95 truck blocks as sometimes only partly machined - missing drilled and tapped holes etc.
However in some 93, all 1994 and 1995 engines GM stopped drilling and tapping the bolt holes in the those provisions in the block
So Its a look and see sort of deal. I really hope mine is OK. If I took the engine completely out for a rebuild, the missing holes would be no problem. That's not the plan though as the lower end is at 108K and has no problems.
cardo0
Post by cardo0 »
Try a vacuum gauge to watch how the engine is loaded in each gear. Got one on the dash of my camaro right where most will mount their aftermarket tachs. Now I can see the engine load even on small grades (just compare to idle vacuum) and I know when the engine is lugging. You can also see the condition of your cylinders in real time and you will know right away if you burn a valve. I think everyone every tow vehicle should have one. It's a large 3 inch gauge with color marks for good and bad economy. But now I know when to down shift out of overdrive when I would never know this w/o a vacuum gauge. Don't know where you can find the larger 3" gauges now but the dail marks are what I would shop for. And I verified the calibration was good at work with a calibrator there.
74 corvette: 350 4 speed
94 Z28: Gen II 350 auto
user-17438
Post by user-17438 »
cardo0 wrote: Thu Jun 07, 2018 11:52 am
the knock sensors can pull a bunch of timing, pulling 20-30hp out if it hasnt been tuned.
donforeman
MTENGINES wrote: Thu Jun 07, 2018 12:10 pm the knock sensors can pull a bunch of timing, pulling 20-30hp out if it hasnt been tuned.
I do have a 1320 Electronics 12 Pin ALDL OBD1 Bluetooth Scanner. I cant say enough good about that company. They helped me when I had an interference problem with the aldl. I can plug in and view and record data on my android phone. knock counts are low. The stock 1995 spark table is a little better than the early versions. Does anyone have a proven spark table for the 193 heads for truck use? I have a few saved that I have gleaned off the internet, but I may not use them as the stock table looks better. They look way too aggressive for even medium towing. I can adjust the table and recheck on the dyno, but burning chips and retesting is a slow process. If I had a head start, it would be a little less work.
ijames
Post by ijames »
Don, are you burning UV eraseable EPROMs? If so, which one? If it is a 27128 or 27256 there are EEPROMs that will drop right in that let you skip the UV step, at least. The stock ECM in my 86 TR uses a 2732 so I made a little board with a ZIF socket to hold a 27128 EEPROM with a DIP switch to select one of 4 images to map into the 2732 address space. I put a plug on the end of a shielded ribbon cable so I had the board in a box where I could reach it from the driver's seat so I could change images or burn a new chip without pulling the ECM. It's been a long time since I did that so I'm a bit fuzzy on part numbers but I can dig it all out if it would help you.
EDIT - Oops, I used a DS1225 which is a battery backed up SRAM, pin compatible with a 2764 so it held 2 2732 images. The larger chips were available I just wanted a minimalist change.
donforeman
Thank you. Most of what you said was too advanced for me. I don't do any of that.
The van is a 1995 so it uses the faster 16197427 ECM. I removed the factory prom from a core and use a soldered in chip holder. The chips I use are SST 27SF512 eprom. I use http://www.tunerpro.net/ and the files found there and on gearhead-efi to burn the proms. The burning of the proms is pretty easy inside the software, its just harder and more time consuming than working with a system like Holley efi.
Just a side note. Billy Graves was a transmission software employee for GM in the 90s and he checked some of the trans files for me. He said because the way the program works, reverse engineered, not from the factory code. There are a lot of faults in the way tunerpro changes the binary code for the transmission. It can cause the trans pressures to not do what you tell it to in the software. So I left the trans pressure tables untouched, altering only the speed vs tps tables that he said were probably safe to alter.
HDBD
Post by HDBD »
What software allows an end user to change major fuel and spark tbi parameters? And then write the changes to the chip?
donforeman
The same software tunerpro. I just mentioned the trans problem for info as it can cause failure and most people cant double check the results.
In-Tech
Vendor
Post by In-Tech »
I've known John Howie at TunerCat ( http://www.tunercat.com/ ) for many years so I've never tried tunerpro. I use an emulator so I can program in real time, then when finished, save the file and burn the chip. You definately want to be careful with the trans parameters, can be easy to fubar the up/down shift tables and TCC lock/unlock and kill a trans in short order if you aren't careful while learning.
I was doing this before software and cheap emulators(Early 90's). All adjustments were made in hexadecimal, then correct the checksum and burn. It was a HUGE learning curve and VERY time consuming #-o
I applaud your effort, it's very rewarding doing it yourself, lot's of reading. =D>
-Carl
In-Tech
Vendor
Post by In-Tech »
94-95 350 4L60E
4168-4288 = Main Spark Table, Open Throttle
428C-43AC = Main Spark Table, Closed Throttle
#-o
Code: Select all
00004160 FF00 0000 0000 0011 5655 5555 5550 4D3F ........VUUUUPM?
00004170 3C36 2E28 2522 1F1C 1A55 5555 5555 504D <6.(%"...UUUUUPM
00004180 3F3C 362E 2825 221F 1C1C 5555 5555 5555 ?<6.(%"...UUUUUU
00004190 554A 4439 362B 2822 1F1C 1C55 5555 5555 UJD96+("...UUUUU
000041A0 5555 5047 4139 302B 251F 1C1C 5555 5555 UUPGA90+%...UUUU
000041B0 5555 5550 4A44 3C36 302B 2522 1F58 5858 UUUPJD<60+%".XXX
000041C0 5858 5858 5250 4741 3C36 302B 2828 5B5B XXXXRPGA<60+(([[
000041D0 5B5B 5B5B 5B55 524A 443F 3936 302E 2E5E [[[[[URJD?960..^
000041E0 5E5E 5E5E 5E5E 5B58 504A 443F 3C36 3633 ^^^^^^[XPJD?<663
000041F0 6464 6464 6464 645E 5B52 4D47 413F 3C39 ddddddd^[RMGA?<9
00004200 3666 6666 6666 6666 615E 5B50 4D4A 4441 6fffffffa^[PMJDA
00004210 3F3C 6969 6969 6969 6966 615B 5550 4D47 ?<iiiiiiifa[UPMG
00004220 4441 3F72 7272 7272 7272 7264 5E58 5552 DA?rrrrrrrrd^XUR
00004230 4D4D 4A47 7272 7272 7272 7272 6661 5B58 MMJGrrrrrrrrfa[X
00004240 5550 5050 4D72 7272 7272 7272 7266 615B UPPPMrrrrrrrrfa[
00004250 5855 504D 4A47 7272 7272 7272 7272 6661 XUPMJGrrrrrrrrfa
00004260 5E5B 5852 504D 4A72 7272 7272 7272 7266 ^[XRPMJrrrrrrrrf
00004270 615E 5B58 5250 4D4A 7272 7272 7272 7272 a^[XRPMJrrrrrrrr
00004280 6661 5E5B 5852 504D 4B00 0011 5455 5555 fa^[XRPMK...TUUU
00004290 5550 4D3F 3C36 2E28 2522 1F1C 1A47 4747 UPM?<6.(%"...GGG
000042A0 474D 504D 3F3C 362E 2825 221F 1C1C 4747 GMPM?<6.(%"...GG
000042B0 4747 4D55 554A 4439 362B 2822 1F1C 1C55 GGMUUJD96+("...U
000042C0 5555 5555 5555 5047 4139 302B 251F 1C1C UUUUUUPGA90+%...
000042D0 5555 5555 5555 5550 4A44 3C36 302B 2522 UUUUUUUPJD<60+%"
000042E0 1F58 5858 5858 5858 5250 4741 3C36 302B .XXXXXXXRPGA<60+
000042F0 2828 5B5B 5B5B 5B5B 5B58 5550 4744 3C39 (([[[[[[[XUPGD<9
00004300 302E 2E5E 5E5E 5E5E 5E5E 5B58 504A 443F 0..^^^^^^^[XPJD?
00004310 3C36 3633 6464 6464 6464 645E 5B52 4D47 <663ddddddd^[RMG
00004320 413F 3C39 3666 6666 6666 6666 615E 5B50 A?<96fffffffa^[P
00004330 4D4A 4441 3F3C 6969 6969 6969 6966 615B MJDA?<iiiiiiifa[
00004340 5550 4D47 4441 3F72 7272 7272 7272 7264 UPMGDA?rrrrrrrrd
00004350 5E58 5552 4D4A 4744 7272 7272 7272 7272 ^XURMJGDrrrrrrrr
00004360 6661 5B58 5550 4D4A 4772 7272 7272 7272 fa[XUPMJGrrrrrrr
00004370 7266 615B 5855 504D 4A47 7272 7272 7272 rfa[XUPMJGrrrrrr
00004380 7272 6661 5E5B 5852 504D 4A72 7272 7272 rrfa^[XRPMJrrrrr
00004390 7272 7266 615E 5B58 5250 4D4A 7272 7272 rrrfa^[XRPMJrrrr
000043A0 7272 7272 6661 5E5B 5852 504D 4900 1000 rrrrfa^[XRPMI...
-Carl
