Using Blair to spec a Cam
pastry_chef
Re: Using Blair to spec a Cam
Post by pastry_chef » Thu Jun 07, 2018 4:18 pm
pastry_chef wrote:
Thu Jun 07, 2018 2:07 pm
2.28/1.70 valves and 48cc chambers.
http://forums.maxperformanceinc.com/for ... ostcount=2
Possibly these larger valves were version 2 of the heads.
Mike R
Big Speed
Post by Big Speed » Mon Jun 11, 2018 1:01 am
Just for reference ,about 9 years ago we built a 535 Pontiac at 10.9 cr .Tiger heads at 535CFMs 2.250-1.800 45 degree seats.1/16 rings .Very compromised Tiger manifold cut to fit under hood.Vacuum pump .Made 896HP at 6900RPMs.CAM was 272-292-114 Mid 800s lift.Typing from home do not have build sheet here.4.350bore .4.500 stroke 6.700 rod .spherical dish.Bill C.
Ceralli Competition Engines & Checkered Flag Machine
Racing engines , CNC head porting and induction development
http://www.checkeredflagmachine.net/
Stan Weiss
Post by Stan Weiss » Mon Jun 11, 2018 2:38 am
Thanks Bill.
Did you run this on Pump gas?
Stan
We have a package of more than 3025 DFW or FLW Files
GARY C
Post by GARY C » Tue Apr 09, 2019 11:12 am
Stan Weiss wrote:
Fri May 11, 2018 2:20 pm
Let me start by saying if you are not going to post anything that adds something technical to the thread PLEASE don't post. I know that could mean this will be the only post in this thread. :lol:
Let see how using Blair will help me select a cam.
I am going to use a 535 ci Pontiac engine for this example. bore = 4.35", stroke = 4.5", rod = 6.7", cr = ??? (Pump gas), Intake Valve = 2.22", Exhaust Valve = 1.77".
I want 900 HP @ 7500 RPM
Torque = (Horse Power * 5252) / RPM
► (900 * 5252) / 7500 = 630.24
BMEP = (Torque * 150.8 ) / Cubic Inches
► (630.24 * 150.8 ) / 535 = 177.645
Since Blair uses metric 177.645 = 12.2482 Bars
► BMEP_BARS = 12.2482
► (5.02 * BMEP_BARS + 57.78 ) / 10000 = 0.0119265964
► (1.7775 * BMEP_BARS + 74.822) / 10000 = 0.009659317549999999
► (4.1185 * BMEP_BARS - 17.985) / 10000 = 0.00324592117
► (3.0296 * BMEP_BARS - 11.363) / 10000 = 0.002574414672
► (1.6329 * BMEP_BARS - 7.1871) / 10000 = 0.001281298578
► (2.4022 * BMEP_BARS - 14.57) / 10000 = 0.001485262604
OK, so what is my next step?
Stan
Stan, did you ever make any progress on this program?
Big Speed
Post by Big Speed » Tue Apr 09, 2019 5:32 pm
Correction That set of Tigers flowed 435 CFMs Engine was 535 Cu In
PRH
Post by PRH » Tue Apr 09, 2019 8:44 pm
This is quite a bit different than the calculated 101lsa, almost single pattern cam.
justanothermelvin
Post by justanothermelvin » Tue Apr 09, 2019 10:40 pm
It is difficult to keep up with all of the changes in the engine data, but the models shown on Controlled Induction 7.08 have different values for port flow and rocker ratios. The math is also incomplete and not completely accurate and is why Rick created 2020. Also the 119%VE is unobtainable by that port.
The model displayed on 2020 have user errors, as is evident by the intake port flow of 368 CFM at .555" lift and the 300 fps design velocity displayed. You should download the new Version 3.01 Stan, it will prevent those kind of mistakes.
I modeled this engine using 11:1 mcr, an intake port flow of 330 CFM at .558" valve lift, 1.8:1 rocker arm ratio with .014" lash at 7500 rpm. Controlled Induction calculated a required TRAPPED VE% of 107% to achieve the 900 HP, and a mean port velocity of 353 fps to achieve that VE%. The Peak Piston CFM Demand for 107% VE was 429 CFM, which using a max port flow of 434 CFM at .800" was barely obtainable. The Potential VE was calced at 119%, but was not available as the Peak Piston CFM Demand for 119% VE showed 479 CFM which that port cannot deliver.
At a mean port velocity of 353 FPS the cam calculated as follows
.050" 284 - 295
.100" 259 - 268
.200" 221 - 228
.300" 188 - 192
.400" 153 - 154
V Lift 1.084" - 1.052"
lobe c/l 113 - 115
This is not a good model as is evident by the cam requirements, especially when the port stops increasing flow at .800" and is not capable of 353 fps mean velocity.
Modeling the 535 Pontiac that "Big Speed" posted as a reference, Controlled Induction 2020 version 3.01 calculated a 272-288 with .858"-.833" on a 113 LSA compared to the actual 272-292 with mid .800 lifts on a 114 lsa. Although, the CBHP was 50 shy of the reported 896.
After reading all of this information being shared, I don't believe the timing events are terribly useful for comparison. IMO, with the same cid at the same RPM, it seems that the port volume and flow characteristics, VE%, area of the valve opening curve and opening curve itself drastically change the intake valves optimum closing point.
Stan Weiss
Post by Stan Weiss » Wed Apr 10, 2019 12:35 am
Stan
Gary,
No I did not. This thread can to an end about 10 months ago and this just got behind other things to do.
Stan
Stan Weiss
Post by Stan Weiss » Wed Apr 10, 2019 12:37 am
.050" 284 - 295
.100" 259 - 268
.200" 221 - 228
.300" 188 - 192
.400" 153 - 154
lobe c/l 113 - 115
Thanks I do have CI 3.01. But I think you have missed the point of this thread. The point was not to find a cam for the engine. It was to see if we could go from Blair's time area numbers back to the needed cam profile. I am not even sure where some of my files for this are anymore. What I had done with a few cams was to take their lobe lift files to see how they matched up to Blair's number.
Stan
