Th 400 problem
Transmission to Rear-end
janne1
Th 400 problem
Post by janne1 » Thu May 03, 2018 11:03 am
TCI valve body man , when I go to third gear it goes to complete stop , what is the problem #-o #-o
"Real Racecars don't make Power with the front wheels they LIFT them!!!!"
mike hohnstein
Re: Th 400 problem
Post by mike hohnstein » Sun May 06, 2018 11:12 pm
You're not getting intermediate oil behind the L/R piston. Probably covering a plate hole with gasket.
janne1
Re: Th 400 problem
Post by janne1 » Mon May 07, 2018 1:38 pm
Ok thanks ,but the car is a street driven car probably around 500 miles, and then this happens
numboltz
Re: Th 400 problem
Post by numboltz » Sun Jun 24, 2018 1:01 am
Somewhat related, so I might as well throw it out there. Way back in ancient history, when Transgo first
made the -3 version of their shift kit for 400s, the very first one I ever installed [complete O/H] locked up
solid in 3rd. After lots of wasted time, it was core shift in one of the pump halves. With all the bolts snug and
the two castings lined up in a case [or with a band, etc.] if you took the slop out in one direction, it locked
up as above. If you went the other way, it was OK.
