1320 Feet MPH Comparisons between V8, V6, S6, 4 Cylinders
maxracesoftware
Re: 1320 Feet MPH Comparisons between V8, V6, S6, 4 Cylinders
Post by maxracesoftware » Mon Apr 16, 2018 8:28 pm
This! At the top end, the drag force per HP has a rapidly growing effect.
Yes , Aerodynamics Losses are growing at a Cubed Rate !
Meaux Racing Heads
MaxRace Software
Stan Weiss
Post by Stan Weiss » Tue Apr 17, 2018 11:13 am
Larry,
I do not know if you ever ran any simulations on the data that George said that I could share with you? I used .52 and 5.5 which is 2.86 and for my simulations that seemed to work out very well against his actual run numbers.
Stan
maxracesoftware
Post by maxracesoftware » Tue Apr 17, 2018 12:42 pm
Larry,
Stan
i never ran a Quarter Mile simulation on George's ProBike ... i just ran/checked his posted Engine Data in v4.00 PipeMax to see correlations
... at least i cannot remember doing a 1320 ft analysis of each foot distance
i might have done a quick sim of just 60,330,660,1000,1320...no real in-depth study
i probably have George Bryce/Angelle Sampy 's best Runs/incrementals logged
but if you like please post the incrementals , ( or any screenshots of your Sims on ProBikes , etc )
because i have that Data logged ... but no actual Team or Racer's name next to each Data Line
so it might take me hours researching to matchup Incrementals to actual Racer's name
How did Bryce/Sampy best 1320 FT MPH compare to similar 1320 FT ET from a ProStock 500cid V8 ?
Meaux Racing Heads
MaxRace Software
maxracesoftware
Post by maxracesoftware » Tue Apr 17, 2018 12:55 pm
Larry,
Stan
Jerry Savoy's ProBike usually has the fastest 60 Feet times of all the Pro Bikes !!!
Jerry is big Alligator Farmer ... Wayne Segura and Sons Alligator Farm is probably one of Jerry''s Competitors
Wayne's Son lives just a block away across the highway from my Shop ... Seguras are relatives to my Family :)
Meaux Racing Heads
MaxRace Software
Stan Weiss
Post by Stan Weiss » Tue Apr 17, 2018 1:45 pm
Larry,
This is something that I had exchanged with George
Hi George,
I ran a simulation based on one I had done back at the end of the 2013 season with some input from you. I added some traction and adjusted the weather / dyno correction factor.
60 Foot ET = 1.0461
330 Foot ET = 2.8086
1/8 Mile ET = 4.3022
1/8 Mile MPH = 164.0001
1000 Foot ET = 5.6116
1/4 Mile ET = 6.7311
1/4 Mile MPH = 201.0191
With the pro stock cars my MPH is normally a little low while here it seems a little high.
For that run with a 1.040 60 foot time I get
60 Foot ET = 1.0400
330 Foot ET = 2.7989
1/8 Mile ET = 4.2917
1/8 Mile MPH = 164.0656
1000 Foot ET = 5.6008
1/4 Mile ET = 6.7201
1/4 Mile MPH = 201.0463
The only way I can get the MPH to come out the same is if I have the engine hit the rev limiter before the finish line.
Stan
---End Quote---
Me too LOL.
It has been a few years since I did this so I any not sure where all of the data is. If you need anything else ask and I will see if I can find it. I also may have to email it to you.
Thanks Stan for asking and keep it private.....i am okay with Larry....please ask him to keep it that way , thanks
Stan
maxracesoftware
Post by maxracesoftware » Tue Apr 17, 2018 2:07 pm
Stan , i found i had done a quick Calc ...here is results ( George said they were just under 400 HP @ 9600 RPM ?? )
6.7500 = 1/4 Mile ET in seconds
198.0300 = 1/4 Mile MPH
630.0 = RaceCar Total Weight with Driver in Lbs.
5.500 = Net Frontal Area in Sq.Ft using recommended SAE .85% Rule
0.520 = Drag Coefficient [ Cd ]
100.000 = Hood Scoop Ram-Air Efficiency %
97.500 = Drivetrain Efficiency %
96.000 = Traction Efficiency %
1500.0 = Density Altitude Feet
1.045108 = Weather HP Correction Factor Air Density PerCent % = 95.684
---- Various HP numbers as you cross 1320 Feet ----
222.5 = Drive-Tire HP at 1320 Feet distance
151.5 = Aerodynamic HP Loss at 1320 Feet distance
17.4 = Rolling Resistance HP Loss at 1320 Feet distance
18.5 = Ram Air HP gain at 1320 Feet distance
HP = 399.6 Engine Dyno Flywheel HP at 600 RPM/SEC acceleration test rate
( SAE J607 STP-MotorSports 85% Mech Eff%, 29.92 inHg., 60.0 degF, 0.0% RH )
291.7 = RollOut Distance Launch HP
2.809 = Maximum Launch GForce 1769.6 = Lbs-Ft Maximum Launch Force
Recommended Drive-Tire Width = 9.8 to 12.7 Inches maximum width
---- 1/4 Mile Incrementals ----
- 0.1488 = RollOut ET in Seconds 9.1665 =RollOut MPH (at 12 inch Distance)
6.7500 = 1/4 Mile ET 198.0300 = MPH
the real incrementals for that 6.7500 ET - 198.03 MPH were :
1.068 2.825 4.318 164.11 5.625 6.750 198.03
NHRA 500cid ProStock Car nearly same 6.7500 ET Group :
Code: Select all
0.988 2.802 4.313 162.94 5.613 6.741 205.22
0.991 2.815 4.334 162.08 5.639 6.741 204.26
0.991 2.811 4.331 162.06 5.641 6.744 203.86
0.996 2.817 4.339 161.63 5.646 6.748 204.51
0.999 2.822 4.340 161.81 5.647 6.751 204.45
1.022 2.837 4.353 162.51 5.655 6.753 205.76
0.990 2.806 4.329 161.69 5.644 6.753 203.06
0.998 2.815 4.336 162.06 5.649 6.756 203.46
1.004 2.835 4.353 162.90 5.659 6.758 205.16
1.001 2.824 4.344 162.45 5.654 6.759 204.11
so a 204.45 MPH minus 198.03 MPH = 6.42 MPH Loss for the ProBike 2 Cylinders -VS- 500cid V8 Cylinders
Meaux Racing Heads
MaxRace Software
Stan Weiss
Post by Stan Weiss » Tue Apr 17, 2018 2:32 pm
Larry,
I did a little searching and found these which are the numbers from run which I based the first of the two simulations I posted on.
Air was fast. 75 degrees, 29.80 Baro, Tail wind
1.046
2.810
4.305
163.89
5.610
6.730
199.76
I do not know what the tail wind was. At that time my software did not include using wind or direct.
I also found I had this information if you want another run. Raw data from NHRA.
; Weather conditions: air temperature 73 degrees, relative humidity 47
; percent, barometer 29.92 inches, adjusted altitude 1,527 feet,
; track temperature 110 degrees.
; Michael Ray Runs 6.793/197.74 -- incremental times: 60ft-1.056 sec.,
; 330ft-2.832, 660ft-4.342/162.14 mph, 1,000ft-5.660.
Stan
maxracesoftware
Post by maxracesoftware » Tue Apr 17, 2018 2:38 pm
just a quick ETCalc Sim gets pretty close :
Meaux Racing Heads
MaxRace Software
maxracesoftware
Post by maxracesoftware » Tue Apr 17, 2018 2:43 pm
.... and again .... even closer in this Sim :
Meaux Racing Heads
MaxRace Software
Wombat57
Post by Wombat57 » Sat Nov 10, 2018 9:55 am
Long time lurker 1 st post. This (ST) is by far the best forum I’ve come across f outstanding technical info with ((usually) minimal drama. Larry - forgive me for picking nits but just checking my admittedly aging/ancient M.E. training - is aero prop to v^3 or aero v^2 x friction = v^3? Great info btw! Thx
Wombat
Brian P
Post by Brian P » Sat Nov 10, 2018 12:22 pm
Aerodynamic drag force is velocity squared. Aerodynamic power is velocity cubed since power is force x velocity.
Friction/drag has multiple components, some have force independent of velocity, others have higher exponents.
Keith Morganstein
Post by Keith Morganstein » Wed Nov 21, 2018 10:29 am
Fri Mar 02, 2018 6:00 pm
( not a Forum Question, instead 1320 Feet MPH Comparisons info )
ProStock V8 500cid -vs- ProStock MotorCycle 2 and 4 Cylinders
even though the CDA of the ProBike is less than that of a ProStocker
the ProBike's 1320 Ft MPH is often 3 to as much as 7 MPH slower )
even though the incrementals at 330, 660 , 1000 are very close in most cases
and even the 660 FT MPH are still very close...but by the time you get to 1320 FT
the more Cylinders + larger CID have more MPH
basically the same thing can be seen even if the CDA's are closer
like in the Automatic/Converter Cars with V8's -vs- 4 or 6 Cylinders
they likewise have lower 1320 Ft MPH than V8 Engines
CDA = the Drag Coefficient x times the Frontal Area in Sq.Feet
CDA = the Drag Area
Unfortunately the images no longer display. Where did the straight six come out in comparison?
maxracesoftware
Post by maxracesoftware » Wed Nov 21, 2018 12:45 pm
PhotoBucket went down ,
now it seems they are back up ??
would be the same results as V6
Meaux Racing Heads
MaxRace Software
Post by pdq67 » Sat Nov 24, 2018 10:09 pm
The OP might want to consider this little-bitty JEWEL!!
https://www.hotrod.com/articles/rescued ... -underdog/
My HR issue is sitting on top of my throne's water tank. I read about it again, earlier.
maxracesoftware
Post by maxracesoftware » Thu Feb 21, 2019 2:50 am
Thanks pdq67 for that Link
i saved the entire Article on my Computer
my 1st Cousin across the Street from my Shop had a V8Cyl 215ci, all-aluminum Olds F-85 many years ago
eventually the engine started burning oil/smoking , still fun to drive :)
i just started working on this new ET Calculator ( Old-Leftside New=Rightside ) goes up to 1600 Feet
Meaux Racing Heads
MaxRace Software
