Worn spark plugs power loss if there's no misfire?
rfoll
Re: Worn spark plugs power loss if there's no misfire?
Post by rfoll »
I have a friend that experienced something similar in a Ford Aerostar. Well over 100K on the plugs, and the straps completely burned off. It was running fine.
Post by Firedome8 »
The Ion sense function can be effected by plug type and mileage.
Smokey
DanE1
Post by DanE1 »
My wife's 6.2 Raptor now has a little over 120,000 miles on the original plugs and I can tell a difference in the sound of the idle. So, I took it for a ride and the engine has a slight pause at tip-in, but then pulls strong but a little flatter.
I could probably remove the plugs, file the electrode flat, file the ground strap flat and back so it just gets over the electrode, and reinstall the 16 plugs. But I probably won't. I'll probably just install 16 new plugs. Might run better with the old plugs set up. At one time I spent a lot of time with a spark plug pressure machine learning how to make a plug continue to spark under more pressure. Oh well..................
barnym17
Post by barnym17 »
What I've found with Fords 4.6 with c.o.p ignition is the normally run fine till you go to start it and it simply will not start. We had this quite a bit I have measured gaps at over .250 before they did this.
Truckedup
Post by Truckedup »
barnym17 wrote: Wed Feb 21, 2018 8:20 am What I've found with Fords 4.6 with c.o.p ignition is the normally run fine till you go to start it and it simply will not start. We had this quite a bit I have measured gaps at over .250 before they did this.
I have heard some vehicles will fry will fry a dual outlet coil when the gap gets huge... When the GM HEI was new ,ignition trying to fire badly worn plugs could burn up the rotor...
Geoff2
Post by Geoff2 »
Yep, what Truck said about burning rotors. Then people blamed the HEI design,when the problem was not a design problem at all, but lack of maintenance...
barnym17
Post by barnym17 »
it will eat the plug boots on the 4.6 and sometimes kill coil.
