Are we building burger cruisers or is this Speedtalk?Tom68 wrote: ↑Sun Dec 31, 2023 12:18 amNecessary evil, flow though is only bad for economy and emissions, good for chamber purging and flame shows.hoffman900 wrote: ↑Sun Dec 31, 2023 12:06 am
Literally, Billy Godbold, Mike Jones, the late Harold Brookshire, and I’m sure unnamed cam designers, all tell you they could care less what the overlap is. It is a result.
You only have so much time to fill a cylinder, and any wasted fuel is wasted power. They're internal combustion engines at the end of the day (not air pumps like people wrongly attribute them). You can literally can convert that fuel to power potential lost.
The events and mechanical limitations of the valvetrain (and the derivatives it can handle) dictate the overlap area, and it is always more than enough, and most likely more than an engine needs. It’s almost that simple.
Like the I4 examples people asked about. I’ve been involved in a few of those. They all have small bores with heads with no included angles, so they are absolutely starving for air. Furthermore, valvetrain geometry, lifter diameter, and rocker placement means valve lift is limited. Add in they are relatively low revving, and now you have a lot of duration to make up for lift limitations, your EVO and IVC events means with all that duration, you have way more overlap than you’d ever want.
I do know of an example where Mike spec’ed a cam for one of those engines types and his centerlines and events meant for a wider LSA. The engine made more power and used less fuel than just about every other design over 40 years of racing history. How about that…
