I run my solid roller springs at 0.050" from bind,if and when you go into float you want to minimise the distance the valve travels,it doesn't take much to widen the seat from bounce.skinny z wrote: ↑Wed Sep 13, 2023 10:25 pm Is there something to be said for too much spring and an excess of coil bind height?
It's been suggested here (and elsewhere) that's it's better for the spring to be operated closer to it's coil bind than it is further from it. Seems counter-intuitive in a way but might make perfect sense from a harmonic perspective.
FTR: I also had a 26918 fail. Use set although it was reunited with the same cam it started life with. Spring are circa 2005.
I was recently advised by the "local" guy who designed my cam to move away from the PAC 1219 and go with the 1218X instead.
Valve Spring Specs.xlsx
On combos that run tight piston to valve, coil bind would be pretty important I would think.
