Testing racecar battery
oldhead
Post by oldhead » Sat Jan 06, 2018 7:10 pm
I am in phila. we race from march to november. I drive mine every week or so during the winter. How do you test your battery for the coming season :) :) :) :) Oldhead
Quicker then most
Tuner
Re: Testing racecar battery
Post by Tuner » Sat Jan 06, 2018 8:06 pm
Touch it to your tongue, lick it.
oldhead
Post by oldhead » Sat Jan 06, 2018 8:14 pm
Do you do that alot
Quicker then most
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Sat Jan 06, 2018 8:19 pm
Do a full recharge, if its holds more than 12.8V after an hour you good to go. (assuming its a 12V batt)
'71 Z28
Pump gas N/A SBC 427
3308 lbs-29x10.5 Hoosiers
1972ho
Post by 1972ho » Sat Jan 06, 2018 8:23 pm
You can take to Oreillys and have them do 1 hour load test.
DaveMcLain
Post by DaveMcLain » Sat Jan 06, 2018 8:52 pm
To properly test a battery you really need a carbon pile type of load tester where you can crank up say a 400 amp load and watch the voltage. A good healthy battery will pull down but when the load is removed return to near its full voltage over and over again. A weak battery will fall off to less than 9.5 volts very quickly and not recover. Cheap electronic battery testers will not do this.
oldhead
Post by oldhead » Sat Jan 06, 2018 11:57 pm
Now this sounds like a real load check,How low do you take the volts on the pull down?????Oldhead
Quicker then most
joe 90
Post by joe 90 » Sun Jan 07, 2018 12:12 am
https://en.wikipedia.org/wiki/Lead%E2%80%93acid_battery
Discharge at the 10 hour rate and calculate capacity.
oldhead
Post by oldhead » Sun Jan 07, 2018 11:24 am
This info. is to old its from 1859, My battery is newer :) :) :) :) :) :) :) :) :) :) Oldhead..PS:Are you that old?
Quicker then most
Keith Morganstein
Post by Keith Morganstein » Sun Jan 07, 2018 6:38 pm
The Midtronics style of tester is used by most shops these days. Many auto parts stores will test your battery with one for free. I’ve used one for over ten years now.
http://www.midtronics.com/transportation
Alan Roehrich
Post by Alan Roehrich » Sun Jan 07, 2018 7:29 pm
O'Rielly's uses the AutoMeter battery tester and charger now.
Absolutely the very best battery tester is an old Sun VAT-28 carbon pile load tester.
plg054
Post by plg054 » Wed Jan 17, 2018 12:38 am
With all the batts on our farm I bought a Solar BA-5 tester a few years back that will check volts CCAs and such. Best piece of test equip I ever bought. Plug.
