47.5 rule for flat tappet camshafts
Stan Weiss
Vendor
Re: 47.5 rule for flat tappet camshafts
Post by Stan Weiss »
Momus wrote: Tue Dec 26, 2017 10:10 am Image
Stan Weiss wrote: Sat Dec 02, 2017 9:30 am Let me add just one more thing about the intake lobe. It is a little asymmetrical. The center line got at 0.006" lifter raise (which just short of lash point) is about a degree different than at 0.250" lifter raise.
Stan
Sorry but it is not my cam data. Unless Karl says it is OK to post a graph or more detailed information I can not.
Stan
hoffman900
Post by hoffman900 »
I’ll have some new plots relatively soon. One will be an ‘70s era Yamaha design, and the other a ‘80s era Megacycle design.
-Bob
Stan Weiss
Vendor
OK, this data was sent to me by someone who used a dial indicator and degree wheel and measured the cam every 2 degree.
Stan
hoffman900
Stan Weiss wrote: Tue Dec 26, 2017 1:10 pm OK, this data was sent to me by someone who used a dial indicator and degree wheel and measured the cam every 2 degree.
Stan
Resurrecting this one as well. Stan, what is that profile from and what are you showing?
Karl,
If you're still lurking...
Read these by Kevin Cameron:
TIOC May 2005
Eaten Alive by Parasitic Oscillations
by Kevin Cameron
As a new hi-fi amplifier is designed by an electronic engineer,
particular care must be taken to be sure that unforeseen combinations
of resistance, inductance, and capacitance do not permit so-called parasitic
oscillations; to build up, destroying the music.
Each property of electrical circuits has a mechanical analog, and one
mechanical system that is often rife with its own parasitic
oscillations is the valve train. Rocker arms bend, pushrods compress
and expand, camshafts deflect between their bearings, and valve stems
flop from side to side while valve heads deflect like trampolines or
floppy disks. All of this is invisible to us. Its symptoms are valve
seat recession and valve spring and valve breakage. In many cases,
after tests with a new cam that gives really good power, we have to
reluctantly back up to a previous, less powerful set-up because we
can't afford the DNFs and breakages that the hot set-up
produces. Valve train failures are hit-and-miss, trial-and-error, a
mystery. Lighter valve train parts and stronger springs sometimes just
seem to make everything worse. Is there any truth?
Back in the 1920s Percy Goodman decided it was time to put aside
clattering pushrods and adopt trendy OHC valve drive on the TT
Velocettes he manufactured. Soon he was driven crazy by erratic valve
motion and sensibly resorted to the use of a strobe light to reveal
what was happening. But naming the illness is not the same as a cure.
When I was recently at the NHRA drag nationals in Houston, I had the
opportunity of conversation with Byron Hines, whose purpose-designed
giant 160-cubic-inch V-twin engine has recently begun to win Pro Stock
races. I asked what had made the difference after some uncompetitive
seasons.
The Spintron, was his answer. It showed us that our valve
motion was nothing like what was in the cam profiles.
seasons.
Spintron use a big electric motor to spin your engine while a variety
of instrumentation is used to measure the actual trajectories of the
parts you are interested in. This is different from using a
strobelight in that the information you get is detailed enough to
allow the flexing of each part to be isolated and understood.
Byron went on to say that valve train dynamics are particularly
difficult to control in big twins because of the large variations in
crank speed as each cylinder fires. The cam profiles were originally
developed to work at a particular maximum rpm, provided that the
camshafts turn smoothly. They do not turn smoothly because the crank
does not turn smoothly; it advances in a series of fairly violent
jerks. 80 percent of the recoverable energy in the hot combustion gas
does its work between 10-deg ATDC and 80 ATDC. Out of the 720 crank
degrees in the engine cycle, power is given during only 10%. This
means that the instantaneous speed of the cam can often be much higher
than its average speed. This also means that as a cylinder fires and
the crank accelerates suddenly, an open valve in the other cylinder
may be tossed right off its cam profile, or dropped prematurely onto
its seat.
This reveals why tuners of singles and twins found that their bikes
top-ended better and faster the heavier their cranks were made. A
younger generation of tuners has rejected this idea as turn-of-the-century
dirt-track nonsense, reasoning that physics requires lighter flywheels to
result in faster acceleration.
Vintage racer Todd Henning learned the heavy crank truth
in back-to-back testing of his highly tuned Honda twins, as did Rob
Muzzy in 1981-83 with 1025-cc Kawasaki in-line fours. The heavier the
crank, the smoother its rotation becomes, and the less power stroke
disturbance, or is transmitted to the cams. Where
does the lost power go when a light crank is used? Erratic valve
motion is one answer, and big valve bounce after closing is another.
Power pulsing is not the only disturbance to the valve train. Consider
a parallel twin, a flat twin, or an in-line four. In all of these, all
the pistons stop simultaneously. This means that as pistons decelerate
to a stop, the crank must accelerate rapidly because there is nowhere
else for the pistons' energy to go ; its conservation of
energy. Peak piston speed is about 1.5 times mean piston speed. This
means that all the kinetic energy in the pistons, moving at near 100
feet per second, is suddenly dumped into the crank. This is especially
bad for in-line fours, which have small-diameter cranks and little in
the way of flywheel mass. This sudden crank deceleration/acceleration
cycle is performed twice per revolution. No wonder new engine
development usually involves coping with cam drive breakage. No wonder
there are mystery failures of valve train parts.
Allan Lockheed is the man behind the engine design software Engine
Expert, and he talks to engine people all over the world. He has
tales of engines whose valves were stable with a chain or belt cam
drive, but which mysteriously began to break valve springs as soon as
a much more rigid gear drive was put in its place. The slight
flexibility of chain or belt took the sharp edge off the sudden crank
speed variations, preventing high frequency motions from reaching the
valve train. This may be why Yamaha retain a chain cam drive in their
M1 in-line four MotoGP race engine. The oil film between each of the
cam chain's pins, bushings, and rollers can be thought of as a kind
of viscous damper. Such fluid film damping is one of the motivations
inclining the designers of rocket engine turbopumps to give up rolling
element shaft bearings in favor of plain journal bearings. A gear cam
drive has fewer than 10 oil films between the crank and cam, but a
chain has a great many more.
Phil Irving, designer of Vincent motorcycles, suggested construction
of parallel twins with crankpins not at the traditional 360 degrees,
but separated by 76 degrees. With usual rod ratios, the piston reaches
maximum velocity at about 76-deg ATDC. At this point, the crank arm is
at right angles to the con-rod; the condition for maximum piston
velocity. This crankpin angle would therefore cause one piston to be
stopped when the other was at maximum speed. The result would be that
the two pistons would exchange their kinetic energy only with each
other, and not with the crankshaft, eliminating one important source
of cam drive disturbance.
Wide-angle Vee engines are better in this respect than parallel twins
but even they have their problems. The classic Cosworth DFV V8 GP car
engine of 1967 was estimated during design to have no more than a 35
pounds-foot torque peak in its cam drive, but actual testing revealed
peaks ten times greater; leading to drive failure. As the engine
was already near production when this was discovered, designer Keith
Duckworth had to scurry around and design a compact spring drive
(analogous to what is found in clutch cush hubs) that could be
incorporated into one of the gears in the drive.
Another approach is that seen on certain WW II German V-12 aircraft
engines, and on late race versions of Honda's RC30. In these and
other cases, small flywheels have been attached to the cams
themselves.
It is interesting to note that both Velocette and Ducati have found
that changing the stiffness of cam drive towershafts can be used as a
tuning measure to adapt an engine to a given race track a stiff
towershaft on short courses, and a more limber one for longer
tracks. The parts seem stiff and strong only in our imaginations and
in our not-very-stiff protein hands. In fact, at speed, everything in
engines is flexible because the amounts of energy moving from part to
part can be so large.
Byron Hines noted that as useful as Spintron's instrumentation is,
even more so is the experience and advice of Spintron personnel. One
of the first things they suggested was that he replace his aluminum
rocker arms with steel, for accurate motion depends more on stiffness
than on weight. He also said that full benefit from Spintron requires
making several laps through their process. A first lap involves re-configuring
the cam profiles and valve train to settle the motion and eliminate float
and excessive bounce. A second lap becomes necessary when it is realized
that after lap one, the engine's power curve has sagged in some places.
This is because before, cam timing and lift had been unwittingly chosen to
at least partly compensate for the uncontrolled valve motion. Once the valve
motion is settled, timing and lift are wrong. Now lap two consists of finding
new optimum cam timings and profiles to again maximize power. That, in turn,
brings to view new dynamic problems to be solved in lap three, and so on.
The people with the greatest sophistication in all this are, naturally, NASCAR engine
builders.
As an extreme example of what can happen, airflow
pioneer Jerry Branch was once called upon to dyno a special V-twin
that was conceptually a slice off a small-block Chevy, crank and all.
Being intended as a motorcycle engine, it had no flywheel other than
its little piece of V8 crankshaft. Branch said that although the engine
had plenty of displacement and hot tuning parts that suggested an
easy 100-hp, it never made over 35 horsepower. Each time it fired,
with almost no flywheel mass to smooth the pulse, it launched its
valves into orbit.
Another aspect of unplanned valve motion is the vibratory modes of
valves themselves. Particularly with rocker-arms (which exert some
side-thrust), a valve can be excited laterally as it lifts, the head
of the valve whipping from side-to-side on the stem; the stem
possibly made more flexible by undercutting to squeeze out that last
CFM of airflow. When this flopping valve approaches the seat, one edge
can hit first, causing a motion not unlike the final stages of a spun
coin's motion. Or, approaching its seat squarely, the rim of the
valve stops but the stem and center of the valve head keep right on
going; the trampoline mode of valve flex. When the motion
at the center finally stops, the valve head is quite deformed and it
now snaps back, tossing itself back up off the seat in a cycle that
can make several hops; with considerable lift being reached in the
process. This is a cautionary tale for those who wish to carve away
valve head mass in search of ultimate lightness. Or for those who wish
to replace existing valve shapes with something quite different. Think
about it if things don't go right. You may have made transformed
those elegant chunks of metal from valves into springs.
Spintron is not cheap but all of us can afford imagination. If you
have valve or spring problems, think about what has worked in your
experience with your particular engine, and what has not. Careful
mental sorting here can reveal a lot. Besides, what else is a body to
think about while waiting for a dental appointment? Sit with the
engine and rotate it through its cycle, thinking about what is
happening at each point. Over time you can develop a mental picture of
what may be happening and what might correct the problems. There is
more to valve trains than light parts and heavy springs."
Early computer-controlled engines had cam position sensors to tell the computer which cycle they are on. Now they do without - they just use the speed difference in the crank to tell them (I guess the engine sparks at every TDC during start-up). So, yes, there are very large speed variations, especially with singles and twins - enough that they give the two cylinders different fuel and ignition maps. Enough, for example, to toss the valves prematurely because the instantaneous cam speed is high. One speed variation comes from the actual cylinder firing, and others come from the steady exchange of kinetic energy between the pistons and the crankshaft (which is twice per revolution).
Nearly every race engine in history has had to have special attention given to the cam drive during development, because crank/cam interactions, through the flexibility of the drive (or lack of it, just as often) create problems. Cosworth make a trick torsion spring that goes in their gear cam drives, and has with it a stack of tiny clutch plates compressed by a diaphragm spring, to absorb the oscillatory energy at the speeds where it tends to get out of hand. Ducati found they had 32nd-order torsionals in their camshafts. They made a big improvement when they changed from ball bearings to plain - every plain bearing is also a hydraulic shock absorber. The oil pump refills it and the thumps of valve acceleration squeeze the oil out of the bearing.
Torsionals were a HUGE issue in the development of the large radial aircraft engines. Generally they had a 4.5-order (firing frequency) and a 2nd-order (secondary vibes coming from the asymmetry of the master-and-links con-rod system) dynamic counterweight on the crank - really massive things that swung back and forth, alternately storing the excess energy from a cylinder firing, then giving it back as the firing impulse died away. When this wasn't right, pieces would vibrate off the tips of hollow steel propellers - chunks about 18" long, going about 500-ft/sec. Or the prop reduction gears would crumble, or the shaft crack, &c. It was a major part of development - hours and hours of running tests to get the crankshaft system stable.
A few years back the NASCAR guys were floating the valves in the back of their engines. This looked like cam twist so they bored some blocks for bigger bearings, increased the cam base circle, and made some experimental cams on bigger tubes. Imagine their surprise when they got LESS power. After a while they figured out that enough valve float to increase time-area, but not enough to wreck the parts, was what was happening. SO next they designed cams to float intentionally, and gradually learned how to design the ski jump so the skier didn't lose his balance when he landed after the jump. At first, these were used just for qualifying. Now they use such "lofting" cams for 500 miles, and the Europeans are calling them "Ballistic valve trains". I think it can work only because NASCAR engines don't run across a wide range of RPM. The guys at Spintron have books and books of development records of this kind.
and the last half of this:
http://www.aetconline.com/wp-content/ed ... odbold.pdf
Sections of this discuss the velocity change and how to mitigate it:
http://www.f1-forecast.com/pdf/F1-Files ... P2_09e.pdf
I asked Billy about this, and he was the one involved with the V&H Spintron test. He said even without firing, you could see the velocity change on the Spintron. He said a twin and a single cylinder will have to have smoother lobe designs than just about anything else to help mitigate this. Something to keep in mind when figuring out how much more there is in there. Short of going on a Spintron, it's all just a guessing game and relying on your cam designer's experience.
-Bob
Stan Weiss
Vendor
hoffman900 wrote: Sat Feb 10, 2018 5:48 pm
Stan
Bob,
That is from a Yamaha r6
Stan
Pguppy
Post by Pguppy »
Isky claims that the Comp XE cams violate the 47.5% rule. The 47.5% rule applies to flat tappet cams for SBCs with 1.5 rockers but the concept is still the same for other configurations where the designs are "on the edge" or "over the edge" for lobe intensity. For 1.5 ratio SBCs, the duration at .50 must exceed 47.5% of the total valve lift or your asking valve train problems. For example, take a Comp Cams Magnum 280H, with 230 duration and, 480 lift...230/.480 = 47.9% which exceeds 47.5% therefore would not pose a threat to components. We do not regularly hear about the older, safer HE and Magnum designs rounding off lobes anywhere near as often as the XE cam designs. Unfortunately, some of the Comp Cams XE dual pattern lobes break this 47.5% rule on the intake side so they are likely to be problematic. The design has "steeper" ramps that are too quick for durability and reliability according to other cam manufacturers. They will wipe lobes in a heart beat especially if you have not followed the proper break-in procedure. Other designs are more forgiving during break-in and less likely to fail.
ones got 215 duration with .450 lift,215/450=.47.7%
the others got 215 duration with 510 lift/215/500=43%
one factor I will mention is that each manufacturer tends to look at durability, ramp speeds and max lifter acceleration very differently, one reason I tend to prefer CRANE & CROWER is that they both company's in general realize the engine must finish the race to win and a busted valve train is a HUGE problem, they both realize, and design valve train components and cam lobes with DURABILITY and reliable valve control as top priorities that are far more important than squeezing every possible potential HP from a cam lobe design at the expense of long term durability
Found this thread on http://garage.grumpysperformance.com/in ... post-65828
MELWAY
Post by MELWAY »
Pguppy wrote: Thu May 06, 2021 10:33 pm Isky claims that the Comp XE cams violate the 47.5% rule. The 47.5% rule applies to flat tappet cams for SBCs with 1.5 rockers but the concept is still the same for other configurations where the designs are "on the edge" or "over the edge" for lobe intensity. For 1.5 ratio SBCs, the duration at .50 must exceed 47.5% of the total valve lift or your asking valve train problems. For example, take a Comp Cams Magnum 280H, with 230 duration and, 480 lift...230/.480 = 47.9% which exceeds 47.5% therefore would not pose a threat to components. We do not regularly hear about the older, safer HE and Magnum designs rounding off lobes anywhere near as often as the XE cam designs. Unfortunately, some of the Comp Cams XE dual pattern lobes break this 47.5% rule on the intake side so they are likely to be problematic. The design has "steeper" ramps that are too quick for durability and reliability according to other cam manufacturers. They will wipe lobes in a heart beat especially if you have not followed the proper break-in procedure. Other designs are more forgiving during break-in and less likely to fail.
I have kind of seen this first hand. The older longer ramp designed cams last a very good long time. And Comp x e hyd and solid flat tAppet profiles fail at break in or within 1000 miles of street driving
I put this down to too fast Ramps and less than perfect lifter bore alignment
CamKing
Post by CamKing »
Here's a very popular circle track lobe design of mine, that we've been running for a couple decades.
.377" Lobe Lift x 1.6 Rockers = .603" valve lift
249 @.050"
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
F-BIRD'88
Post by F-BIRD'88 »
I think the biggest issue today is the quality of the FT S and H lifters..
djr48312
Post by djr48312 »
hoffman900 wrote: Sat Nov 25, 2017 2:12 pm Some more:
Harold Brookshire:
Since if there's anything I know, it's History, here goes.....
Prior to the widespread use of computers, very few mushroom cams were made. The earlier designers had enough trouble making cams follow their normal lifters, much less an extra-wide one.
By the mid-70's, NASCAR racers had learned enough to know that the Chrysler .904" tappets allowed more aggressive lift curves than the .842"-.874" tappets. NASCAR's compromise?---Let everyone use a Mushroom lifter. Chevrolet went to .960", and NASCAR settled on that, even though Chrysler had some 1.000" ones. Those were used in drag racing.
In 1978 I designed the Comp Cams' 310/318 mushroom cam, 268/276 at .050, .390"/.410" lobe lift. In 1980 Buddy Baker won the 1980 Daytona 500 with this cam, and it is still the fastest Daytona 500 ever run. NASCAR went to restrictor plates, and then to .874" max tappet diameter.
Cams with flat-bottom lifters, either hydraulic, solid, or mushroom, are design-limited by velocity. Here are the max safe velocities(more or less) for the various lifter diameters:
.842" .00705"/°
.874" .00733"/°
.904" .00759"/°
.960" .00808"/°
There ARE tricks around these numbers, but not all cam designers know them, or else how to use them right.....
Cams with rolller lifters, either hydraulic or solid rollers, are design-limited by acceleration and base circle diameter. A peak acceleration rate that may be un-makable for a .900" base circle may be usable for a 1.100" base circle.
There are obviously tricks around these limitations, also. The hard part is knowing the tricks, not the basic theory, and when and how to use the tricks....
You and I are probably calling different things 'aggressive', but basically, yes, mushroom tappet cams are more aggressive, even older ones.
The thing is, whatever you can do to a .842" tappet, you can also do to a .960", only the lifter is moving about 15% faster. That is a whole lot faster in cam design.
If you're not careful, you can move the intake valve faster than the air can follow the intake valve/piston. Then the engine is always overcammed---I have done this in NASCAR, and I have had to slow the cam down---dealing with .874" tappets!
My famous 288R roller cam would require a 1.155"(VW-size!) mushroon tappet if I cut it out as a flat tappet cam, as it is over .0094"/° at max velocity.
Flat tappets, hydraulic or solid, are limited by max cam velocity. If the velocity gets too high, the point of contact between the lifter and the cam moves to a point OFF the lifter. The edge of the lifter starts digging into the cam lobe, and it wears out in a very short time.
Each different diameter lifter has its' own limiting velocity, however, bigger lifters on a smaller-diameter lifter profile do not lift the valve any faster. They only make a larger contact point, lowering wear on that combination.
The limitiing velocities are around .007"/* for .842" lifters, about .0073"/* for .874" lifters, and over .0075"/* for .904" lifters.
Roller cams are not limited by velocity at all, but by peak acceleration rates.
If you accelerate the lifter too soon and too hard, the cam becomes hard to manufacture, and even impossible in some cases.
Flat tappets accept a higher acceleration rate than roller tappets do. Flat tappet rates run from .00035"/*2, to over .000600"/*2. Small block Chevrolet roller cams start forming inverse radii(the plural of radius) at .000350"/*2. At the same time, peak velocities run in the .009/" to .010"/* range.
As you can see, there's good and bad with both of them.
UDHarold
BTW---In the 1960s possibly into the early 1970s, Crane Cams used to offer the same lift curve in solid and in roller form. They did not look alike at all, but like the typical solid tappet and the typical roller tappet camshafts.
They look the way they do because of how the models are made. At UltraDyne I used a 1 1/2" wide flat wheel to make solids and hydraulics, a different wheel with a .350" radius for hydraulic rollers, .375" for solid rollers.
To move this thread back towards its' subject, the truth is they can be of equal aggressiveness.
It all depends upon the cam designer.
Back in 1980, when I started UltraDyne, I designed a flat tappet 288 at .020 cam, and a roller tappet cam, also 288 at .020. they were both 255 at .050, but there it stopped. The flat tappet was 166 at .200, and .360" lobe lift. It was the most popular flat tappet cam we made.
The roller was 176 at .200, and .4176" lobe lift. It was the most popular roller cam we ever made. In the same 355 SBC at ProMotor Engineering, there was a 60 BHP and 30 ftlb of torque difference in favor of the roller.
Yet measuring Major Intensity from .020 to .050, they were both 33 degrees. I do not remember the offset on the flat tappet, but the roller was 15 on the opening side, 18 on the closing.
Currently, ALL my solid lifter designs, both VooDoo and racing, are 28.68 MI for the same .020 to .050, with 13.44 on the opening, 15.24 on the closing. My popular 31 MI designs are 14.02 on the opening, 17.29 on the closing side. My oval track/SuperStock rollers are 28.43 MI, 13.45 on the opening, 14.98 on the closing.
As you can see, both solid lifter and roller lifter designs have just 28 degrees of Major Intensity, and are of equal aggressiveness.
However, other factors come into play. The roller has a lower peak acceleration than the solid lifter, but a much higher peak velocity(.00937"/* vs .00704"/*).
We've been able to achieve 5* LESS Major Intensity in the past 29 years, and still keep the .050 durations and .050 offsets exactly the same. Both the .200 duration numbers and the lobe lifts have gotten higher.
Ain't science wonderful?????
ith a valve spring bucket 1.38" in diameter, you divide by 2(.690") and subtract your clearance from the edge(.690"-.020"=.670"), then divide by 57.3. Your answer should be .011693"/* max velocity. A higher design velocity gets closer to the edge of the spring bucket----How brave are you?
Finding out this number is most easily done using various cam analysis software, such as CamDoctor, etc. Trying to measure it with a degree wheel is nearly impossible. Most cam designers should be able to give you this number on any given design---For instance, all my current solid flat tappets for the SBC/BBC .842" diameter lifter are at .007041"/*. My old .960" diameter mushroom designs were around .00807"/*. Most of my roller designs are in the .0085"/*-.0095"/* range.
Velocity numbers are only important in flat tappet solid and hydraulic designs, acceleration numbers are important in roller designs.
The highest lobe lift I have designed a DOHC bucket follower for has been .575", and yes, it did not run off the tappet.
So this data basically says that a valve spring bucket of 1.38" diameter supports more cam profile acceleration than even a solid roller cam with .842" bore?
Tom68
Post by Tom68 »
djr48312 wrote: Sun Jan 14, 2024 1:59 am
By bucket you mean cam on bucket ? Versus a solid roller with a rocker arm, then I'm sure the answer is no.
djr48312
Post by djr48312 »
Harold Brookshire:
.842" .00705"/°
.874" .00733"/°
.904" .00759"/°
.960" .00808"/°
UDHarold
Accleration of the lifter. At the valve the acceleration would be acceleration of the lifter x the rocker arm ratio. So for this solid flat tappet with max velocity .007041 it would be .007041*1.7 = .0119697 and the roller design would be .0095x1.7= .01615. So the 35mm bucket ( 1.38" ) supports a max velocity of the .011693" or similar to a solid flat tappet with 1.7 rocker arms.
Tom68
Post by Tom68 »
The thing with rocker arms is you can't just simply multiply by a constant ratio through the lift curve. The ratio is not constant throughout the lift curve.
djr48312
Post by djr48312 »
Tom68 wrote: Sun Jan 14, 2024 2:26 pm The thing with rocker arms is you can't just simply multiply by a constant ratio through the lift curve. The ratio is not constant throughout the lift curve.
I appreciate the response. But it is certainly greater acceleration at the valve than the acceleration of the tappet, but not perfect as you said because the ratio is not consistent thru it's range of lift.
