Air filter on Dominator
redliner
Post by redliner » Tue Nov 14, 2017 12:33 pm
What is the best airfilter set up to run on a Dominator carb? I saw a test on you tube that was for 4150 style carbs and they used a velocity stack with a tall K&N filter that gained h.p. over no filter scenario. Does anyone make a velocity stack for a Dominator or is this not the way to go? Is a Dominator designed to be run with no air fiter? It seems to me that may be the case.....
mag2555
Re: Air filter on Dominator
Post by mag2555 » Tue Nov 14, 2017 12:50 pm
If you saw that YouTube video then you know that the first factor to be addressed is how much HP your looking to make , the Carb is the second factor.
redliner
Post by redliner » Tue Nov 14, 2017 1:59 pm
True! Camking says it orta go 630+
redliner
Post by redliner » Tue Nov 14, 2017 2:00 pm
True! Camking says it orta go 630+ I have the carb nailed down,tis the filter setup I need
andyf
Post by andyf » Tue Nov 14, 2017 3:17 pm
Run a tall one if you have the room for it. K&N makes elements that are 5 and 6 inches tall. If you have room then use one of those. If you don't have the room then do what you can.
Andy F.
AR Engineering
cgarb
Post by cgarb » Tue Nov 14, 2017 4:41 pm
The salad bowl filter!...lol
redliner
Post by redliner » Tue Nov 14, 2017 5:00 pm
I was actually thinking about it!!!! I still might!!!!
cgarb
Post by cgarb » Tue Nov 14, 2017 5:02 pm
The salad bowl makes sense to me logically and it parallels with their dyno results. Air pulling across the carb messes with the airflow. Hard for air to make a 90 deg turn effectively.
redliner
Post by redliner » Tue Nov 14, 2017 5:12 pm
I am really hoping to find a dominator velocity stack and put a filter on it. Any ideas?
cpmotors
Post by cpmotors » Tue Nov 14, 2017 5:19 pm
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
Cylinder Head Fixture for Vertical / Surfacing Mills
bill jones
Post by bill jones » Tue Nov 14, 2017 5:21 pm
-this topic shows a large 16" K&N for a dominator.
http://www.speedtalk.com/forum/viewtopi ... 87#p373687
redliner
Post by redliner » Tue Nov 14, 2017 7:30 pm
I think I will try and find a velocity stack for a dominator, anyone know where I can get one?
