Mercedes F1
MikeD
Mercedes F1
Post by MikeD »
RCJ
Re: Mercedes F1
Post by RCJ »
If nobody told you, Would you know that was a motor?
The Radius Kid
Re: Mercedes F1
Post by The Radius Kid »
RCJ wrote:If nobody told you, Would you know that was a motor?
Yes.It's not hard to tell that's an engine.
tjus
Re: Mercedes F1
Post by tjus »
funny how they had to limit oil consumption in f1 engines....
peejay
Re: Mercedes F1
Post by peejay »
I saw an article about that... controlled oil consumption to bring octane down.
They have minimum octane, not maximum octane...
MikeD
Re: Mercedes F1
Post by MikeD »
There seems to be some controversy in F1 that some manufacturers are "leaking" oil into the combustion chamber to increase power. Not sure how that works. Seems counterintuitive.
j-c-c
Re: Mercedes F1
Post by j-c-c »
My understanding, motor oil has a BTU component when burned, since fuel amount/flow is limited, the engine oil becomes a work around, and obviously they tune for it.
cjperformance
Re: Mercedes F1
Post by cjperformance »
MikeD wrote:There seems to be some controversy in F1 that some manufacturers are "leaking" oil into the combustion chamber to increase power. Not sure how that works. Seems counterintuitive.
Basically due to very high rpm a lower fuel octane to speed the burn is helpfull, this is why F1 have a 'minimum' octane NOT a maximum octane. When oil enters the combustion chamber it effectively reduces the octane of the burnable fuel which is an advantage power wise to an F1 engine.
peejay
Re: Mercedes F1
Post by peejay »
I don't think it is necessarily "burns slower" as much as it is that they had/have been running the engines on controlled detonation, since they were finding the burn speed limitations of gasoline-ish fuels. If you can't get it to burn fast enough, make it detonate!
cjperformance
Re: Mercedes F1
peejay wrote:I don't think it is necessarily "burns slower" as much as it is that they had/have been running the engines on controlled detonation, since they were finding the burn speed limitations of gasoline-ish fuels. If you can't get it to burn fast enough, make it detonate!
They have a MIN octane as the F1 guys want lower octane than they are allowed. So use the control fuel then 'add some oil' and they get the lower octane they want.
carmakerevive
Re: Mercedes F1
Post by carmakerevive »
I wonder if they're getting a good even burn across the chamber with the oil in there.
"Poor planning on your part, does not constitute an emergency on mine..."
ptuomov
Re: Mercedes F1
Post by ptuomov »
I personally think that they are more likely to burn the oil in the exhaust port and manifold than in the combustion chamber. Oil in the combustion chamber is a bit difficult to control as it cause preignition. In the exhaust manifold, it can be used to run the turbo, which has the electric recovery system attached to it.
Put Search Keywords Here
tjus
Re: Mercedes F1
Post by tjus »
Schurkey
Re: Mercedes F1
Post by Schurkey »
When did 50% become "more than half"?
Circlotron
Re: Mercedes F1
Post by Circlotron »
Schurkey wrote:When did 50% become "more than half"?
When someone says "up to 50% or more" :evil:
