fishman wrote:I installed a roller solid cam in my 383 for the last race of the year...when i did piston to valve clearance i got if i remember right with zero lash...exhaust was 28 thou and intake was around 50 thou....anyways i tore the heads off and the intake to get send out for porting, i noticed on each piston the exhaust valve has made an impression in the build up on the piston and i can see a shiny round ring from the outside of the valve....whewwwwww no bent valves but it has to be damn close...the fix this problem what do u guys recommend...
1 going to a thicker head gasket
2 taking the motor apart and fly cutting the piston
3 or dropping the exhaust rockers to 1.5 from 1.6
Thanks any input would be greatly appreciated
Ed-vancedEngines wrote:Changing the rocker ratio to a lower ratio could help some. Not becuase of reducing maximum lift. Maximum lift has no bearing whatsoever pertaining to valve to piston clearances.
Changing rocker ratio while not affecting the actual total duration by much, it will alter the effective duration once the valve leaves the seat. If the ratio is increased the valve leaves the seat harder and starts moving quicker, so your measured lifts at all points in low and mid lifts will show an increase as measured, and will actually hold the valve open longer, because the valve opeing events will start sooner and will close later.
Let me try to explain this a little better. Let us say that with your 1.60 rockers, your measured lift at .250 will be earlier in the duration cycle, than it would be as measured at .250 with the 1.50 ratio. That same measured lift with 1.50 would be at a later point in the engine's rotation.
Am I making any sense?
It still seems that I am not doing a very good job of explaining this. In your degrees of engine rotation it will only be where the valve lifts are during the points of overlap that will be closer to the piston. Maximum lift means nothing. The valves get closer to the piston at 5 deg to 20 deg before and after TDC. Those are extreme examples that would cover anything used in the amount of camshaft retard or advance. Usually it would be closer to 10 deg to 12 deg, but it is still good to cover all the bases.
The long and short of it is that at valve overlap where it gets the closest to piston, a lower rocker ration should give you some more available valve to piston clearances.
This is not accurate becuase it is only an average that I worked out for me to use years ago;
Advance cam by 1 deg = .007 increase of Ex & decrease of In V/P clearance.
Retard cam by 1 deg = .007 decrease of Ex & increase of In V/P clearance
I just use this as my rule of thumb as an average to get an idea with. Each application will vary some.
If this engine is run only as Normal Aspirated AND you have a fairly thick margin you could cut down the face of the valve some. I suggest a minimum Intake Valve margin of .060 and a minimum Exhaust Valve margin of .075. IF guys that do this all the time tell you different listen to them instead.
With a normal aspirated engine I am a tight quench fanatic, but you can play with head gasket thickness some and still keep a quench effect.
It is possible to cut valve notches deeper while piston is still in the block if that is necessary.
That is a few options for you to think on.
Ed
fishman wrote:You guys are the best...thanks alot...i am a sponge absorbing all of this
I have a couple questions on your answers
1.. cutting the valve is one way u say off gaining clearnce...is that a safe practice or is it done all the time.
2 changing the cam postion on advancement notch will gain clearnce...can somebody explain this as i am quite not sure how it works...like 108 degree cam...110 etc......i am new at this and learning
3 flycutting the piston the piston has to be taken out of the block to this or not and does it change any balance issues...my piston r light weight mahle only weigh 495 grams for a 383 stroker.
thanks alot guys
Users browsing this forum: 540 Vette, Baprace, gmc406, mustangmike68, racerx1622, Sprinter99 and 8 guests
