Manual valve body stall question
Transmission to Rear-end
BOOT
Post by BOOT » Sun Jan 29, 2017 1:37 pm
If you have a manual valve body do you need a high-ish stall? For example if you were to use a 2000 stall with manual valve body th350.
Alan Roehrich
Re: Manual valve body stall question
Post by Alan Roehrich » Sun Jan 29, 2017 2:06 pm
The stall speed of the converter has no bearing on the valvebody.
peejay
Post by peejay » Mon Jan 30, 2017 8:32 pm
2000rpm is high? My '72 Ford had a 2200rpm stall straight from Dearborn (429-4v in a Thunderbird) and my current daily driver has a 3000rpm stall converter, straight from wherever the hell they made the car, Swedish car built in the Netherlands with Japanese-American transmission, I think that averages out to Azerbaijan or something...
BOOT
Post by BOOT » Mon Jan 30, 2017 11:49 pm
I should have said for example with a low 2000 stall, just assumed it was a known low.
