A problem at times un-noticed, is refered to as 'rough combustion'. It means what it says. ------ When you get into differing air quality based on humidity/temperature, it gets worse.
We all know how the chamber is everything, so your typical tub style of chamber of the Ford/23*Chev, makes high-high compression less desireable as reacting smoothly.
One customer claimed a 23* GM alcohol package cranked 320 on the dyno. Pretty much could not drive it this way. (Sprint). But he did this to teach himself what did what, -------- and the cam/piston was quickly changed to be further tolerable in every way, but it was alcohol.
I can say in my past experience, that when you drop compression & you gain power on gasoline fuel, it's rough combustion. ------ Look into this concerning how touchy your Ford is & you should learn what's happening as I read into your question. -------
Nitromethane taught me this, way to long ago.
