Larry from maxracesoftware has said that when the pitot diff. pressure exceeds the test pressure, the velocity is too high, and power will suffer.
When someone with as much experience as Larry - on Flow Bench AND Dyno - shares something like that with us, I take it as fact....-ozrace
ozrace....thanks for the vote of confidence
from a SpreadSheet =>
VALVE-------------------------------Prime Choke
LIFT--------28 in------- Area------- Velocity
0.2--------- 145-------- 1.587------ 83.755
0.3--------- 230-------- 2.380------ 132.852
0.4--------- 335-------- 3.173------ 193.502
0.5--------- 410-------- 3.966------ 236.823
0.6--------- 475-------- 4.760------ 274.368
0.7--------- 525-------- 5.553------ 303.249
0.8--------- 550-------- 6.346------ 317.690
0.9--------- 555-------- 7.139------ 320.578
1----------- 560-------- 7.933------ 323.466
23.87" Pitot Probe Velocity Pressure..at 1.000" Lift ..depending upon Port's Corner Radius
23.87 " when Flow Testing at 28" inches H2O
the 23.87" in the smallest "Port" Cross-sectional area doesn't equal or exceed the Flow Test Pressure in a ProStock Head ..even at 1.000" Lift
very hard to see evidences "Sonic Choke" inside modern ProStock Intake port (not including Short Turn Apex area)...just barely at early stages of Choke.....if you were to epoxy up that smallest cross-sectional area to the point where you would measure 28" or higher on a Pitot Probe...all the while not seeing any loss in Flow...and if the Heads would still Flow = 560 cfm @ 1.000"...you would see HP/Torque Losses on the Dyno, especially after the RPM point of Peak HP....after that point, HP would drop like a rock with a Choke problem
you would need a cam with 1.149" lift to see effective 1.000" Lift
or epoxy that area a little smaller ...and Choke would occur around .900 to 1.000 of lift...the Head would stop flowing and pumping losses would increase until either side of choke velocity or max lift point
the head will not flow anymore at Choke, but pumping losses will increase
very , very easy to have a Sonic Choke problem in an old SuperStock SBC head if you aren't careful
if the ProStock's smallest cross-sectional area is reduced to 3.840 sq.inches area and flow 560 CFM at 28" of Test Pressure you will be at Sonic Choke in live engine...if you increase Flow , or Cam Lift, or reduce this area even further, you will be into severe Sonic Choke
HP will drop 75+ HP easily
3.840 area = ( 560_CFM / 350_FPS ) * 2.4
350_FPS = velocity @ 28" Test Pressure
LPV= 0.00353*RPM*S*B2 divided by CA
LPV= limiting port velocity
S = stroke
B = bore
CA= min port cross section
657.94 fps = (.00353 * 9000 * 3.62 * 4.687 * 4.687 ) / 3.840 area
98.8 " inches in live engine
.5896 Mach at 59 F
Trends=>
if you have a Port on the edge of Choke...increasing things like E/I Ratio
can cause you to loose HP/Torque ..it will make you spread centers and reduce E/I Ratio
