Just wondering if folks had formulas they'd like to share on calculating the hows and why's of engines...
Larry has been great on posting formulas for making calculations. Jsut wondering if we should make a thead to collect them in all in, and if folks had any they wanted to share.
For instance...
ICA = advertised Intake Closing timing (Angle) in degrees ABDC
RD = Rod horizontal Displacement in inches
RR = Rod Distance in inches below crank CL
PR1 = Piston Rise from RR in inches on crank CL.
PR2 = Piston Rise from crank CL
1/2ST = one half the STroke
DST = Dynamic STroke length to use for DCR calcs
RD = 1/2ST * (sine ICA)
RR = 1/2ST * (cosine ICA)
PR1 = sq root of ((RL*RL) - (RD*RD))
PR2 = PR1 - RR
DST = ST - ((PR2 + 1/2ST) - RL)
Cylinder volume = 0.7853982 x bore2 x stroke (plug in DST for stroke here to calculate DCR)
Cylinder volume for Dynamic Compression ratio = 0.7853982 x bore2 x DST
Clearance volume = 0.7853982 x bore2 x deck height
Piston dome or dish in cubic inches = cc's x 0.0610237 (- for a dome + for a dish)
Head-gasket volume = 0.7853982 x gasket bore2 x compressed thickness
Chamber volume in inches = cc's x 0.0610237
Displacement = Cylinder Volume * Number of Cylinders
Compression Ration = Cylinder vol. + clearance vol. + piston Comp. vol. + gasket vol. + chamber vol. divided by Clearance vol. + piston vol. + gasket vol. + chamber vol.
Dynamic Compression Ration = Cylinder vol. + clearance vol. + piston Comp. vol. + gasket vol. + chamber vol. divided by Clearance vol. + piston vol. + gasket vol. + chamber vol.
Piston Speed= Stroke x rpm/6
Header pipe length (in inches) = ((850*(360-EVO))/RPM – 3
Header diameter (in inches) = ((cylinder. disp. * 16.38 / ((hdr len + 3) * 25))) * 2.1
These formulas are from A. Graham Bell’s Performance Tuning in Theory and Practice. For a street engine, the RPM used should be the peak torque RPM. For a race engine, the peak hp RPM should be used.
Optimum runner length:
We must take into account the intake duration, but you want the pressure waves to arrive before the valve closes and after it opens (air wont pass though a closed valve). To do this you must subtract some duration, typically you take off 20-30° from the advertised duration. 30° works well for most higher rpm solid cammed drag motors.
ECD = Effective Cam Duration
RV = Reflective Value
D = Runner Diameter
Effective cam duration (ECD) = 720 - (Adv. duration - 30)
optimum intake runner length (L) is:L = ((ECD × 0.25 × V × 2) ÷ (rpm × RV)) - ½D
Intake Ram Pipe Diameter
The formula to figure out the diameter pipe that should be used is for a given velocity is:
D = Square Root of (CID × VE × RPM) ÷ ( V × 1130)
Where:
D = Pipe Diameter
CID = Cubic Inch Displacement
VE = Volumetric Efficiency
V = Velocity in ft/sec
If you're dealing with liters, change CID to liters and the constant to 18.5 so the formula will look like this:
D = Square Root of (Liters × VE × RPM) ÷ (V × 18.5)
Thanks for any replys...
