DCal wrote:A cutomer recently went 209mph in Pro stock using a .8mm top and second ring with .135 radial walls. These rings will be available in most bore sizes. You can check with Kevin or Keith at Total Seal 800/874 2753
Please come by the CP piston booth at PRI if I have'nt been clear
DCal wrote:CBoggs You're right,I apologize, I never intended to post except to respond to a member of this site that had a problem with one of my employees about gas porting. Failing to do even that correctly, I must admit I can't type and am far too busy to keep up. So I won't respond very often. My name is Dave Calvert and the invitation stands re:PRI. Darrin Morgan turned me on to this very informative site and I'm so pleased to find a site without backbiting and name calling and where everyone is so informed.
bobqzzi wrote:I realize that if you went with 2 rings you'd want to have a piston specifically designed for it;however, would doing a bcak to back dyno test in which you removed the second ring be valid?
Can a 2 ring piston be used without vacuum or drysump in a class where cylinder pressure is low due to rules?
Users browsing this forum: Baprace, Blacktrack, GregGood, racerx1622, SKeown, Sprinter99 and 5 guests
