Transient Response: "Let’s go to the mystery area that’s really what makes the car run….or accelerate. I call it Transient Response or Recovery Time. How long does it take for an engine to recover from being yanked down 2000rpm on a shift and accelerate back to the redline again….that’s the mysterious quality that all killer engines have, and it’s not something that will show up in "conventional" dyno testing. Quite the contrary, I’ve NEVER seen an engine that possessed this quality make big HP.......The only "number" I’m concerned in is: How much time does it take this engine to accelerate a given "load" from point A to point B. If the rpm range you anticipate operating in is for instance from 5000 to 8000rpm, the combination that will pull the "known load" from the bottom to the top the quickest will ALWAYS be the engine to run regardless of HP."
AVL 850 HP/14000 RPM
• Steady state, Transient response and Endurance testing
MadBill wrote:Seems like some of the high-end programmable dynos could simulate this. After all, if Ford could accurately dyno-simulate every lap of 24 hours at Le Mans back in the sixties..
All you'd need is a sturdy dyno and a good controller that could manage say a 600 RPM/sec. pull to redline, then slam it back down 2-3,000 revs and run it up again at maybe 400/sec., etc...
Larry was the supposed writer of that "essay".I do not see or understand what any of that page has to do with Larry Widmer though. I did not even see him there.
Ed
Posted by T.O.O. on June 20, 1998 at 20:14:11:
The PRO STOCK RACING ENGINE
I wish the folow-up to this page was available.Transient Response: "Let’s go to the mystery area that’s really what makes the car run….or accelerate. I call it Transient Response or Recovery Time. How long does it take for an engine to recover from being yanked down 2000rpm on a shift and accelerate back to the redline again….that’s the mysterious quality that all killer engines have, and it’s not something that will show up in "conventional" dyno testing. Quite the contrary, I’ve NEVER seen an engine that possessed this quality make big HP.......The only "number" I’m concerned in is: How much time does it take this engine to accelerate a given "load" from point A to point B. If the rpm range you anticipate operating in is for instance from 5000 to 8000rpm, the combination that will pull the "known load" from the bottom to the top the quickest will ALWAYS be the engine to run regardless of HP."
Users browsing this forum: Baprace, Blacktrack, Google [Bot], GregGood, racerx1622, SKeown, Sprinter99 and 6 guests
